Jeff B
Thanos was right
- Dec 23, 2006
- Lincolnton N.C.
got it muddy in Uwharrie yesterday. now I'll three link the front.
Always lolMight wanna get some gas too![]()
Have heard a lot of negative about them coating lately. I don’t have any recommendations but I have had fair luck with blasting some and putting about 500 coats of high temp paint on mine.Dug the headers for the 454 out; started cleaning them up, had to knock out the old flange bolts but with some gentle persuasion with a punch and hammer coupled with ample amounts of Kroil I managed to get them out without too much hassle.
Anyone got any recommendations for coating places? I got a quote from Jet-Hot, but $400 to get these done up hurts a little at the moment; buy once cry once maybe?
Only negatives I've seen about Jet-Hot has been the turn around time? I definitely don't want to spend a decent chunk of change and not be happy with the resultHave heard a lot of negative about them coating lately. I don’t have any recommendations but I have had fair luck with blasting some and putting about 500 coats of high temp paint on mine.
Carolina Powder in Mooresville did the last set I had done.Only negatives I've seen about Jet-Hot has been the turn around time? I definitely don't want to spend a decent chunk of change and not be happy with the result
I really want something that'll help with underhood heat; Vortec 454s are hot natured, especially when you toss a set of headers in the mix; which is why I looked into Jet-Hot in the first place.
Got everything back in and done. The fabbed repair on the pedal box looks solid.
Transmission is on the floor, and I was right in my diagnoses.
The grease on the bearing guide tube if the input shaft had turned to glue. I couple quick shots of Liquid Wrench and a quick scrub and it clean, ready for new grease and to go back in.
Throw out bearing looks fine ... spins good and smooth.
BUT....
I don't want to do this again!
Question is, are the Inmotion or M-PACT brands from Rock Auto good quality?
