Darell's tj build
baby hulk
concord nc
This is a MarsFab Offroad build.
What's getting built, 98 tj sport 4.0,auto.
What's getting done,Swapping in a dana 44 and a 9" with trac lock lsd 4:88 gear's front and rear (bronco connection) all axel bracket were supplied by (ballistic fabrication) for the suspension going to be using 6" coil's (skyjacker) 2.5" spacer f&r (4 wheel customs) (MARSFAB custom triangulated 4 link rear 3 link front using creeper joint's, with custom trac bar and steering. mars fab will also be building a custom belly pan) to finish the build going to be installing sye (advanced adaptors) new drive shafts (tom wood's) wheel's are procomp 15" semi bead and 37x12.50x15
^is that gonna be the ride height? Little top heavy I'd think. :)
sye
Wonted to keep the fender's for now so that's what he had to have to run 37 38.
Got the sye in and belly pan done.
belly pan
belly pan
More pics of the Ford, please.
:flipoff2:
Darell I got your rear axle and frame link mounts pretty much done today. You need to come check it out when you get a chance. Hopefully the rear will be done tomorrow.
sounds good chris, btw the belly pan looks great and thks again for repairing transfer case gasket also...when u installed sye .
belly pan
Any more pics or details on the custom belly pan? Looks good.
Better pics of the belly pan also has frame mount tacked up for the four link
axels and lower mounts
got everything tacked on the rear end and lower arms mayde
ride height
this should be close to ride height
Pics look good so far...wish I could read the details, but I have to highlight everything you type so I can actually make it legible.
