Roid Rage Roger Buggy Build
Hopefully my links will be put in this week and the motor and stuff mounted
I done the three speed atlas 2.0 2.76 5.44 I am running a powerglide and yeah Larry is going to do the exhaust we have been trying to figure out what I am going to run
I am thinking of running race magnaflows and true duals there isn't enough room to put a x pipe in and it benefit
Thanks man
thinking after breaking into the axle I may need to upgrade
ive seen some 2.5ton shafts break before but they was in 1000hp trucks and 55" plus tractor tires but then again i dont play in rocks lol
I have seen toyota motors break rockwells so that is not saying anything. I called them to get some info on the axles and found that I can only run the stock 5 ton axle in the 2.5 ton housing with cutting and changing the knuckles. Then to run the big boys you have to run the 5 ton with mods it is just to much trouble so I will probably stick with the u-joint axles until I decide whether to go with RCV's or Oversuns
couple new pics
Well I know about the rcvs I don't know if we are going to leave them there so it may.be brought in right beside the knuckle
Looking good Jody!
I can hook you up w/ RCV's if you go that route!
Man thats lookin good that rig is gonna be stout!!
Yeah I may run rcvs I am going to stick with u-joint for now then decide I will let u know Dave. I am trying to figure out what wheels I am going to run now
Found some u-joint replacements for the ball and claw axle that I found when I opened the axle up I think these will due
I hope so I had to give a fortune for them hahahaha so I am not going to complain to much I guess off to the machine shop tomorrow
Got a couple new goodies from a friend in Las Vegas just waiting on the orbitol and steering shaft
Yeah I would like to get the front on the mount this week and the rest of the links mounted up and welded in. The spindles should be done sometime this week and I can get the ouveruns put in the rear and it finished up
