- Mar 20, 2005
- Morganton NC
What are your tricks ?
I have a few.
Leslie came up with the idea that if we can get it started, it will burn. One trick is to use fire logs. You can take one and break it into several pieces and make it last a good while. The cheap ones from discount stores work just fine. You can also use charcoal(match light), and of course starter fluid sure helps a lot.
A good friend and forum member Larry Smith showed me a trick one year at the Dixie run. Many years of being a Boy Scout, I always got down and blew on the fire to act as a human bellows. Anyone has done this knows the draw backs, but it effective. Larry showed me a simple paper plate or foam, as long as it's rigid. Just fan the fire and get it some O2, one of the key elements for a fire.
Another good friend of mine Robbie Mozely usually always carries a chain saw. Many times I have seen him drag an old dead log back to camp and saw it up, giving us plenty of fire wood. This is a good idea especially since some states have laws about bringing wood across state lines(due to bring in wood/tree diseases.
Having a Friend like Steve Brush who always brings a couple boxes of dried wood blocks with him. By products of packing material from his work. The are very dry and will just about light without any additive mentioned above.
So what are your tips?
I have a few.
That guy is nuts!
