My_samurai
Active Member
- Apr 28, 2005
- Columbia SC
Hey all i have been mia for a while here. i started a new project about a 2 weeks ago using a 89 fullsize bronco 351W,C6 3speed and bw1356 tcase so far what i have i the rear rockwell is bolted in using a set of skyjacker lifts springs from a 8" lift kit the srping orginally gave me about 7" of lift. The front is going to be running a set of leafs out of a mid 80's chevy blazer, using the blazers rear shackle, flipped on the front of my bronco. i will have pics coming soon with a whole write up on what i have done and plan on doing..I have a set of 39 boggers on 15" wheels, looking for bigger tires and beadlocks. full hyrdo steering , detroits F/R and shaved pumkins. i figure i would give you guys a heads up on whats going on here is the south this how she looked b4 the rockwells took over....ill have pics tomorrow
I got most of the sus. works done, i still need to put on some front shocks and weld the rear shocks mounts up. i have the rear drive shaft already with 1330joint on the tcase end with out the CV joint and 1410 joint on the rockwell end. i only have one pinion brake right now, ill soon order another. i moved the hydro ram for the steering to the front of the axle and welded on a tab to the rockwells steering knuckle, i had to heat the knuckle to 500* in order to weld on that cast metal..that was a pita. im still lacking one hydro line coming from the pump to the ortial valve, i have a hard time finding the right style fitting for the pump on the pressure port to go to the pressure port on the valve which is a 8n hydro tread any ideas?
100% complete jackass
