Tim C
Wizard
- Jan 22, 2007
- Fayetteville
Could the same swap be done on a 78 f150 with a 400 or 460?
I'm sure it could, but they may need a custom chip burned for it to run right. On my 351 I'm running with the stock chevy 350 tune. The 351m, 400, and 460 use the same distributor. I'd probably look for a chevy with a 454 to get parts from however since the throttle body and injectors are bigger, they'd be better for feeding the larger ford mills. The tbi isn't friendly to wild cams however, so if you're planning on using a cam with more than 218 duration at .050 or less than 112 degrees overlap then you may be better off adapting fords own mpfi onto the 460
