RatLabGuy
- May 18, 2005
- Churchville, MD
They are called Clecos. They come in several versions. The most common is a spring loaded style which require a pair of Cleco pliers to install and remove. There are also threaded style clecos which provide more clamping force than the spring loaded versions. They typically are either 1/8" or 3/16" diameter and are used to temporarily hold sheetmetal in place as you are fabricating and or mocking up. They are used in aircraft fabrication and racing as well.
Ah cool. Learned something new today.
Here's a good explanation too
