- Mar 24, 2005
- Stanley, NC
I've heard Gay Man's Chevy. Works either way.Gay Man’s Cadillac
Gay Man’s Cadillac
I cant make any headway on any diesel choices, which must be a sign. And who am i kidding, ill tow max 2 to 4 times a year. It will be more often just used for wood or parts/tire hauling. Trying to decide between ram or GM 2500 gasser. Anyone got any mechanical input? Thanks
(Edit: Maybe ill find a LB7 for the price of a gasser lmao)
If you want a solid front axle tow rig, you're stuck with a Ford or Dodge. V10 Super Duty trucks are cheap compared to diesel ones. I used to tow with one and it did great. With your budget, you could find a low mile truck in great condition. A Hemi powered Ram would do the job. However, in talking with some buddies at the local CJD dealer, later Hemis are having frequent camshaft and cylinder head issues.
My wife drives a later model F150 with the 5.0. We use it from time to time to drag our camper around. Plenty of power and brakes for towing. Again, they would fit your budget well.
It's hard to beat the GM truck platform for comfort and ride in a tow rig. A 6.0 powered 2500 would get the job done well. Back in the early 2000s I had a Chevy 2500 with a 6.0 that I used to tow a 3/4 ton YJ all over the place with.
I think you'd be very happy with a properly equipped late model 1/2 ton _______ truck for as infrequent as you'll tow. Going with a 1/2 ton will save you money that will allow you to purchase a newer truck.
A half ton?! Didn’t think brake sizes could handle pulling the Jeep even if the frame/hitch could. Wow ok cool. Yeah a lot more 1500 series trucks out there that are newer and cheaper. Thanks for the tip.
Been looking mainly at the 6.0 2500s because of how cheap and simple they are to fix.
What would be a “properly equipped” 1500 series truck?
Are all the newer Ford 5.0s the same? My dad has a 2011 F150 with 5.0 and I've driven it many times, and never thought "man this is a good truck engine". Maybe I'm too used to diesels, but I feel like the 5.0 has to be spun to at least 4k rpms before it starts making any power. His previous 02 F150 with 5.4 seemed to have much more bottom and mid range.
Are all the newer Ford 5.0s the same? My dad has a 2011 F150 with 5.0 and I've driven it many times, and never thought "man this is a good truck engine". Maybe I'm too used to diesels, but I feel like the 5.0 has to be spun to at least 4k rpms before it starts making any power. His previous 02 F150 with 5.4 seemed to have much more bottom and mid range. His 5.0 does get 16-17mpg around town and better on the highway. But the GM 6.0 and 6.2s that I've driven had much more power across the spectrum, especially on the bottom end.
I'll disagree slightly about the Ecoboost. Father in law has a 3.5 and the torque is much better than the 5.0. But if you actually use any if that torque, MPG is worse in the Ecoboost.You’re 100% right (same for the eco boost too). Strictly looking at the power numbers, sounds impressive. If you look at the power curve, not very truck friendly for truck activities. I said it with the original 5.0/302 and I stand by it with the current 5.0, they have no business in a full size truck.
With the GM 6.0 2011and up( I think) are 6 spd, and dedinetly do better all aorund than the 4spd
But do most people who own a 5.0 F150 really use it as a truck? Or is it a car with a bed on it to them? The ones that do use them as trucks probably don't tow often enough for it to really matter that much to them. That's probably the reason why they don't offer them as the gas motor in an F250.
Come to think of it...my 99 Silverado half ton was
They've been using 6 speed autos in the 2500 gas trucks since they changed the body style in 2007.5 and went to the L92 6.0.
couldnt a 6L just be easily swapped in?
regarding the DOD and DI, those are only on 2015 and up? im currently looking in the 2006 or 2007 trim levels (era). I would like to get the 5.3 over the 6.0 for fuel economy, and because swapping in a JY 5.3 is stupid cheap compared to a 6.0 in the event of catastrophic failure. I can get better mpg and more power like a 6.0 with cam and intake upgrades. However, im not sure if the 6L can be swapped over the 4L without computer modifications.
Depending on the real world info, may be stuck with a 6.0 2500. Def wont be going above a 2012 model. The only thing the woman cares about is if the interior is immaculate and if it has or is possible to swap in heated leather seats.
Whatchumeam WAS?!?!? you said you never sell trucks!!
