WARRIORWELDING
Owner opperator Of WarriorWelding LLC.
- Jan 6, 2008
- Chillin, Hwy 64 Mocksville NC
Also weld through primer is a thing.
That's what I was thinking, simpler is sometimes better-- some aluminum tube and heim joints would look and work a lot better.Personally, I like the looks of the 'off the shelf' export braces with round tubing.
Also, be careful posting pictures that include your mail. People are weird.
no problem man, I'm more than happy to take advise on work for customer projects. I'll admit I don't always (or never lol) take advise on my own rig but I try to be humble and learn anything I can when working on other people's stuff. ThanksNot telling anybody what to do, but I personally think it needs it.
is this necessary? I'm not against doing it if needed, just figured it was pointless to weld that entire joint other than for aesthetics, but I'm here asking so to not seem like I know everything (or anything haha)Side note. Are you planning on filling in the stitches on the tower delete plates?
I’m not a welding or fab expert so I’d defer to those guys. I just know that is a very high dynamic load spot and I’d think a continuous weld would be stronger.is this necessary? I'm not against doing it if needed, just figured it was pointless to weld that entire joint other than for aesthetics, but I'm here asking so to not seem like I know everything (or anything haha)
yes and no depending on execution and the load like mentioned. The reason unibody seams are not welded continuous are two fold.I’m not a welding or fab expert so I’d defer to those guys. I just know that is a very high dynamic load spot and I’d think a continuous weld would be stronger.
But there are others better suited to answer that than I. I only asked because it jumped out visually to me.
Well said sir! So I'm still not sure on the answer of leave it (seam sealer) or weld it up..yes and no depending on execution and the load like mentioned. The reason unibody seams are not welded continuous are two fold.
Numero Uno reason is most definitely cost.
Numero Dos leads to your reasoning. A contious weld is very rigid, more so when the weld and material are stronger and thicker then the base material. Any flex of the area is tranfered directly to the seam. Bending forces confined to this long "fracture line" (my words) open up in structural failure. Hence well designed members held in place by resistance spot welds. The weld being a tie in and the members being designed to reinforce each other.
My personal choice would be spot welds that retain a factory type appearance and or a combination of Silicon Braze Tig. The Silicon braze would be a great seal with much less heat input but should not be the relying bond due to lower tensile.
But we are not building a high end car here.........
Well all mine remember had tons of plating and boat sides and such so I wouldn't know hahaLeave it. The old sheetmetal will tear all the way around your haz if you weld it solid. Years of shitty xj bodies should have taught you that
It appears to have had spot welds applied. If they are staggered and placed correctly these will exceed the strength of the parent material. I don't know these cars very well. I am baffled by the flat on flat nature of the panel all together. As it looks it was merely a tie in and way to smooth the original shock tower wheel well area removed for clearance. If that is the case lower in the chassis related to the engine cross member would be a reinforcement area. Most likely handled by the design of the motor mount. The high side should be braced and reinforced by a well place tie ins and relationship to the upper connectors, done in a way to distribute the load across the upper seam. The middle is just extra credit and keep the wheel well spray out.@WARRIORWELDING I would think that it would need at least some stitch welds spaced out?
oh believe me that area is def "reionforced". The new crossmember is straight BEEF!! "frame" rails are plated front to back and on the sides along with Torque boxes and tied into the rockers.If that is the case lower in the chassis related to the engine cross member would be a reinforcement area. Most likely handled by the design of the motor mount.
Fair question and I'm not gonna act like i know the answer so ill wait myself.Genuine question since some more smarter than I folks have chimed in.
Wouldn't it greatly benefit the "strut tower" brace if it captured both the top and side of the fender rail?
Picture a "7" on each end here:
Be a pornstar.Fair question and I'm not gonna act like i know the answer so I'll wait myself.
What?Gross![]()
I'll be honest, a piece of 1"x1"x1/8" wall square or round tube going straight across would be SIGNIFICANTLY stronger than this part you have fabbed and installed.
Something like this?I'll be honest, a piece of 1"x1"x1/8" wall square or round tube going straight across would be SIGNIFICANTLY stronger than this part you have fabbed and installed.
www.globalwest.net
A straight piece of toob with a thin wall would be stronger and stiffer than that even, but yes, that would also be a lot better.Something like this?
1964-1966 Mustang Adjustable Monte Carlo Bar (with a bend over the distributor for clearance) Part Number: TS-8 - Global West Suspension Car Parts
Shop for 1964-1966 Mustang Adjustable Monte Carlo Bar (with a bend over the distributor for clearance) Part Number: TS-8 for the best prices on Global West Suspension Car Parts.www.globalwest.net
The bend is to clear an old school front mount dizzy.A straight piece of toob with a thin wall would be stronger and stiffer than that even, but yes, that would also be a lot better.
