a_kelley
mechanical fixer
- Jan 26, 2010
- Rutherfordton
Though really, sequential really only plays in to any great difference at idle.. above idle a the injector time is almost long enough to not make any power difference.
True. Injector PW is really only a few ms, so I can see that off idle it really doesn't add up much. I could only ever get this engine to idle smoothly at about 8-900 rpm on a carb, but I'm sure I can drive that down a hair lower once it's EFI. But since I don't really see it spending too much time right on idle, it may not make a huge difference, especially for any power gains.Though really, sequential really only plays in to any great difference at idle.. above idle a the injector time is almost long enough to not make any power difference.
Yeah you got the concept of how that would work. If you have two extra outputs you can drop one active component.
That makes more sense now for the switching. Thought for a minute I needed to go dig out my electronics textbook again. Thanks for the input! It'll definitely get my mind working.Crap, just noticed the input to the lower bjt should come off the uc output.
Seriously just learned about 4 things in that one statement... I need to read your threads more often. I've seen a few things in the software about injector characteristics, but I haven't gotten too deep into it as of yet. I figured I'd get it all together, design and build a bench tester, and then tinker with it for a while before I actually build the harness and install. Don't worry, I just might be coming to tug on your shirt sleeve a few times once I get going!I recommend going with FETs if your going to do it.. less heat dissipation needed due to low RDS on & less voltage drop which affects PW also.. inj timing varies with battery voltage. The software should let you input inj latency values..
I should have just bought that bay. Hell, I rented it enough to have paid for it!If you'll notice, that picture was taken at the hobby shop too!
Thanks! I never knew I loved tinkering with electronics until sometime relatively recently. But I'm most certain you could do things like this with your eyes closed. Like I keep saying - I wish I had your skill and imagination with all things metal!If there was a trophy for enginuity, you'd own that shit. Badass! I wish I had the skill to do that.
Never know, we might even team up and build a buggy one day.Thanks! I never knew I loved tinkering with electronics until sometime relatively recently. But I'm most certain you could do things like this with your eyes closed. Like I keep saying - I wish I had your skill and imagination with all things metal!
That would be the shit!Never know, we might even team up and build a buggy one day.
Thanks! And thanks for reading. I have in fact done a TON of research on EFI setups, as well as had a couple....none that I have been able to tune on my own, nor anything anywhere near as extensive as this.@Scooter402 how’s the speeduino stuff compare to mega squirt? Apples to apples or totally different capabilities/intent/required skill set. I could use the google...but I figure you’ve already done the heavy lifting and could fill me in
I wanna turbo my inline 250 one of these days... efi would be a nice complement.
Keep up the good work!
I'll definitely post it up if it's going to help you and/or anyone else. The Microsquirt would definitely do what you need, but this kit would be much cheaper (I'm pretty sure of it, anyway). Much more fun, too, if you are into electronics assembly. Depending on what kind of injection setup you use, you'd have to split your injectors between the 4 drivers, unless you went TBI with only 2 injectors. I'm assuming you'd have at least 4 with TBI, unless you went with an MPFI setup similar to mine. The only difference between this semi-sequential setup and batch fire is having to take a little more care with the initial wiring so you get the injectors wired to the correct drivers...after that, the ECM does all the rest. I'll try and make some decently detailed posts once I get to the wiring and setup portion of this project.Definitely post up the bench tester when you get it done. I'm toying with the idea of putting efi on my fairlane when I get my new motor together. I've been looking at a Microsquirt but I'm going to look into this stuff harder now that I've been following along here.
I've played with a ms3 pro evo system we put on a buddy's BMW, a TPI setup on my dads 67 c10, and I've tuned my own maf equipped Chevy tbi setup on my Ford rockcrawler.
The fairlane I was just figuring batch fire and timing but letting the dist handle the firing order. So the micro would work for me but this looks interesting. I'm loving it so far.
Sent from my HTC6545LVW using Tapatalk
Since I'm a glutton for punishment...I must have been a masochist in some former life. I actually hand soldered it with a fine tip in the iron and 0.5mm wire. I thought I might appreciate doing it that way at least once. Of course, I had to use plenty of flux and a solder wick to take care of a few bridged pins.What method did you use to solder the tssop?
You're the second one I've heard say that! After I got done fighting with this thing, one of the EE's here said it's actually easier with a little bit larger iron. This was me: "oh, now you tell me!" Live and learn, right? I've worked with some SMD/SMT before, but this was a first for me with TSSOP. I'll admit....I was kinda skeered at first!Drag and wick method works pretty well. (Larger iron and flood and wick)
