- Mar 20, 2005
- Hendersonville, NC
Remove caliper, rotor, spindle and caliper bracket. You'll see a hole that is larger than the axle shaft. Pull the shaft out and install some of those "HD greaseable" ujoints we hear so much about.
ha ha ha..thanks man, i really do appreciate it. ur gonna really really slap me now cause i actaully bought one when i dropped 1500 in parts and totally didn't even think to look in the book for how to do it...shows how much of air head i can be LOL. (i feel stupid)Pull the shaft out and install some of those "HD greaseable" ujoints we hear so much about.
this is what i remember doing on my ford ranger D35 front TTB now that i think about it but according to Jody, the D50 is non C-clip...i will have to look in my chiltons tomorrow and hope he's right cause i hated pulling that D35 ttb out now that i think about it and this D50 is way bigger and heavier so i hope not but if i do have to...i guess it's gonna get a "lincoln Locker" before i put it back together since it has lockout hubs.The Ford Bronco i had with the similar TTB front suspension but with D44 did have a C-clip on the mid shaft. I had to take the whole cast unit off the big TTB arm to get that shaft out. I put a Lock Right locker in the front, and the C-clip wont fit back in there with the Lock Right, so it just ran without it and i never had any trouble with it.
unfortunately i have to replace both outers and the passenger long shaft inner joint too so looks like i'm gonna be taking the dam thing apart...ohh boy that will wait for later before winter sets in when 4wd will be needed!True.
I'm assuming he is only trying to access the outers to replace those joints.
i did that on my ford ranger D35 ttb and will do it on this one if i go that route but from the last hour of searching ford forums, everyone says it can be done on the truck with ball joint press and passenger side stuff removed so i think i will try this first...i'm not very fond at all of removing that heavy pumpkin period so i will try m darndest to do it on the truck lol...angel grinder/cut off wheel at the right angles i've read can cut it in half then it's a whole lot easier to remove and new one of course goes right in but i got time before snow comes around for needing 4wd...gotta finish this darn thing first and get it driving and ready for October runGoogle search for "ttb c-clip eliminator" before you put it back together
yeah and to make it worse...a friend just told me i have to take out the trans, slide it back 8-9" or so, take slave cylinder and turn it completely up and let it gravity bleed otherwise there's a place in there that air gets trapped and will never get a proper clutch pedal and such....WTF WTFOhhhh. I didn't know that year was internal slave.
so i'm about to search this internet all night if i have to until i find someone whose done the trick without doing this cause pulling tranny back out is out of the question since that dam thing is so heavy and pain in my a** to set in....took me forever to set it in the first time and there's gotta be a way to bleed this thing out without removing the trans. dam ford designers.when i got the truck it was torn apart but the master had full fluid (I don't know how it didn't leak out with the slave not hooked up)...so i've reinstalled new clutch, internal slave (stock), and bled it the way someone mentioned but still not good enough pedal which now i know since it's making noise. the master never went dry.Get a vacuum bleeder. Def sounds like to me you have air in the lines. Did the master leak all of it fluid out when you where working on it? Is the master new? Has the master itself been bench bled?
yes it has bleeder screw. first i did the pump and bleed like brakes...didn't work too well so i did what someon earlier in this thread told me...pump one time, hold, open bleeder, close bleeder, release clutch....repeat till no more air and straight fluid comes out. I did this and got a pedal but never strong enough pedal and have tried bleeding again and same results. I also just let it gravity bleed about 1/4 of small bottle of brake fluid and nothing, same pedal. I guess the only think i haven't done is sit there and pump the hell out of it 40/50 times like some have said...i'm going crazy with this thing lol. this little crap gets to me more than anything. thank you very much for your helpYour slave has a bleeder screw right? I see so many i cant remember vehicle to vehicle. Tell me your bleeding process.
thank you sir. i never thought of this and makes sense and right now i'm open to any advise to try out in the morning. (any advise on the other stupid issue with my "belt" wanting to slip off the pulleys...i ran ruler across pulleys and they seem to be withing reason of each other??) thank uPush clutch down, let your foot slide off the pedal quickly so that the pedal releases rapidly. This will help air bubbles dislodge.
I've bled numerous Fords this was with success. It may take 40-50 cycles to bleed it completely
alright...this seemed to have worked for 90% of it...noise is gone pretty much and clutch pedal feels WAY better...now only 1" or so of freeplay from the top rather than almost 3", i guess as i start to drive it too from what i hear it will get that last 5% but thank you as you saved me a huge headache this morning and was able to accomplish a good pedal and clacking noise gone within 15minutes.Push clutch down, let your foot slide off the pedal quickly so that the pedal releases rapidly. This will help air bubbles dislodge.
I've bled numerous Fords this way with success. It may take 40-50 cycles to bleed it completely
