skyhighZJ
- May 31, 2012
- Aberdeen, NC.
This was when I had just got things setup. I was a long way from finished but may give you an idea.
too late now, my lower links are on the axle and thy're 3/8 plate boxed in. Ain't cutting those off
Much like boning, it's all about angles and proper length.
A non triangulated 4 link front with a trackbar (think stock zj,xj suspension) Can use a regular steering box with drag link because the axle and steering will move in the same arc as the suspension droops or compresses. With a stock steering system and a triangulated suspension now the steering still wants to move in that arc but the axle wants to move up and down centered under the rig so you will end up with massive bumpsteer.Btw, why do you have to go full Hydro in order to have 4 link front? I've seen this statement a lot but never understood why..
that makes sense, thanks for clarifying thatA non triangulated 4 link front with a trackbar (think stock zj,xj suspension) Can use a regular steering box with drag link because the axle and steering will move in the same arc as the suspension droops or compresses. With a stock steering system and a triangulated suspension now the steering still wants to move in that arc but the axle wants to move up and down centered under the rig so you will end up with massive bumpsteer.
That's why you HAVE to go full hydro with a triangulated front suspension.
its coming along slowly lol. I finally got rear axle under it to mock up wow, LOTS AND LOTS of cutting with plasma cutter to get 40s to fit on 3" lift. I didn't realize how much higher my other xj buggy sat but anyhow, this 3" lift on 40s/tons is little "lower" than expected haha. it's gonna have a mean looking stance that's for sure and very stable with this height. will keep updated once I make some real progress. Boat sides are on (cutting out rockers was a pita).Any updates??
Yes I know lol. But with plasma cutter, saw saw and some Fuller ingenuity anything is possible haha40s under a full body ZJ is going to take MASSIVE amounts of trimming at 3 inches of lift. Most off the shelf lifts for ZJs claim you need 7" springs to run 35s![]()
Two of my buddies had ZJ’s on 42’s. This should be fun!Almost all the weight on rear..so 3" lift will work woohoo
It's different, good in some ways bad in others. I'm liking it so far for the most part lol. More tedious cutting than the XJ. I've got rear axle almost even with the rear so I like that much better. With low to the ground and 117" wheelbase should be way more stable than the other buggy. Longer wheelbase will also favor me when I get a doubler down the road hehe. Well that's it for nowTwo of my buddies had ZJ’s on 42’s. This should be fun!
Ironically enough, the Sterling centersection and axle tubes as far as size are comparable to a Dana 80.Gotta admit that Sterling rear is WAY more forgiving on ground clearance for the tire size vs the D70 I had
Wifey is cute why she with you???Wifey got a workout helping moving the rear axle in. Fun part was me dragging it under the jeep on grassView attachment 291417
This one is looking better than tony the tiger you built last time......
That's because I haven't got to the cage yetWifey is cute why she with you???This one is looking better than tony the tiger you built last time......
Not to bust your bubble @ghost, but you're one ugly SOBWifey is cute why she with you???![]()
Huh..the rear has a truss been done for while. It's on pg 1 I think. Tubes are welded too.Figure out a simple up and over truss or weld the tubes. Keep the updates coming!
