Accidentally building an LJ
I somehow took one single picture of working on the swaybar mounting yesterday. It’s welded, painted, and the bar with the arm brackets is reinstalled now. Next up is attempting to bend the arms.
I’m sitting here deep in researching adapting Tesla electric parking brake calipers onto the back of this thing. There’s a thread going on Irate about it that got the gears grinding in my head. And this YouTube video:
How I use Tesla Parking Brakes in my Jeep!
I’m gonna wait for the guy on irate who ordered a set of calipers to share some measurements to be sure I can squeeze the actuator motors in. I’ll probably do something similar on my C10 at some point too.
Brennan Metcalf has a rear brake kit that uses Ford Fusion calipers for flat fender jeeps. I remember talking to him about doing a kit for your typical one ton brake conversion. He said he had researched it and a F150 had a rear electric parking brake caliper that would take a full size vented rotor. I tried to talk him into making a kit but he was to busy.
That’s a cool idea. I’m going to use the UCF bracket that bolts in place of the factory parking brake bracket underneath and uses the cable to activate a remote Wilwood MC to lock the rear brakes. I’m just going to delete the factory parking brake on the 10.5.
He’s weighed in on the irate thread with some info. I looked at the F150 stuff for my C10 and it’s an option for that truck still. If I remember correctly, the F150 used the same or very close rotor thickness to what’s on the floater 9” I have in the truck. And I think the piston area is only a tiny bit smaller than the GM D52 1/2 ton calipers that are commonly used in the off road world so they’re a solid option for sure. The C10 has a Tilton pedal assembly that I’ve not yet mounted or bought master cylinders for so it’s a nice blank slate starting point.
All of the parking brake stuff was missing from the TJ when I got it so I’d be starting from scratch to use that bracket. I did consider it for a bit though. I’d also like to build an aluminum center console in this at some point so I’d rather wire a switch than have to build around the e-brake handle.
I caved into my impatience and ordered the Tesla calipers last night along with a few of what I’m fairly certain are the right plugs to wire them.
irate thread on the electronic e-brake if anyone feels like reading it.
Got a few minutes to mess with this pile this afternoon so i made the bendy tool for the sway bar arms. Some 1” solid round bar, a piece of steel plate, and a little section of dom. I welded it together and tacked the upper part to my 20 ton press. I ended up bending them in 3 places the way Tony from TK1 told me he does it. It ended up working great and was even pretty easy to get the arms to match. Now I need to make shorter links to connect them to the axle as my guess for that was pretty far off.
I‘ve also managed to find time to get the Swag air/hydraulic stuff set up on my bender. Now I’ve just got to make a stand for it so I can use it. The steel to do it is laying in the floor so I’ll hopefully get that knocked out soon.
Tesla calipers are here too. I’m going to split them and make a 3/16” spacer between the halves to fit my 1.25” rotors. Wiring connectors, a dpdt rocker switch, self resetting breaker, and a reversing relay are sitting here to try and make something that works if I can get them to fit back there somewhere.
The only other thing that’s changed on this thing is that I ended up trading a kind of rough set of half door lowers for a set of full hard doors. I drove the Jeep to Colombia on Saturday in a monsoon with the full soft doors on it so I could stuff them in the back and drive home with the hard doors on. The passenger door is tweaked a little bit but it shouldn’t be too bad to get it back right. And they’re already black so I don’t have to mess with that.
I would love to add a parking brake to the Ghost. I thought about the Eldorado Calipers but have heard they were getting hard to source. I've got a lugnut kit on the D60 rear. I'll have to see if I can find some info on brackets.
apparently Lugnut has a new ebrake kit that doesnt use the eldorado calipers but has a mechanical ebrake. I am following along with all the electric brake work, although 1 caliper that is hydraulic & electric, and large enough doesnt seem to exist.
Late model f150 stuff might be an answer to that. They’re real close in size to the GM D52 calipers that pretty much every rear disc conversion uses and have an electric e-brake built in.
They use a thinner rotor but there’s some stuff out there to fix that. The Irate thread has some good info on that. You’re pretty much locked into a custom caliper bracket to do that as far as I know though.
I don’t think there’s an off the shelf bracket out there yet. I’ve got a set of motobilt brackets sitting here to try out on my main calipers. Whatever the ones on my axle right now are, they’ve only got 4 position options for the calipers and 2 of those are on the bottom side of the axle tube. I’m hoping the motobilt stuff will give me a couple of options to be able to move the main calipers and hopefully open up some space to squeeze the Tesla e-brake stuff in. I’m planning on adding tabs to the motobilt brackets to hold them if I can find room to fit them.
I wasn't aware of this. Going to go look up those lugnut calipers.
The f150 calipers are the same size piston as the small (jb6) eldorado calipers, but smaller than the larger (jb7) ones (2.497"). If someone is currently running a Chevy 1/2ton caliper (2.934") or 3/4 ton Chevy (3.146") it is a good bit smaller. I am currently running a Gm metric caliper (2.375") in the back, so its not too far off. I would like to upgrade to a larger rotor and caliper at some point, once I swap in power brakes.
Bought a new top and finally pulled the dash again to replace the A/C evaporator and got it charged up. It’s pretty much become my dd since then with a couple multi-hour trips thrown in. I still need to dive into the front end so it’s actually 4wd but my kids love riding around in it possibly more than I do so I’m cool with it how it is for now. We also trailered it down to my parent’s house and drove it to my 20 year high school reunion. Fun times.
Take the cowl off and put a piece of metal insect screen over the vent opening with some high quality double stick adhesive strips.
The leaves (esp willow oak) will just get back in there if you don't.
I took a bit of a break from working on this thing due to buying a house back in July. I’m now getting settled to the point that I’ve messed with a little over the last month or two. It took a ride down to Greenville, SC for Carlton Customs to do the gear install in the front RJ60 and get inner shafts made. Waiting to measure for them instead of ordering the 78-79 Ford shafts that supposedly this housing was built for turned out to be a solid move. They wouldn’t have been even close. Only issue the axle has now is a leaky driver side inner axle seal so it’s gonna end up getting torn down at some point to fix that.
I finally got around to getting the rear corner armor cut and installed. It’s taking way longer to do it than I would have guessed it would. Passenger side is cut and has paint drying right now. Lots of holes to locate and cut/drill in addition to the wheel opening on that side. The Genright stretch TJ rocker guards I had weren’t gonna play nice with the Motobilt corners so I ended up buying a set of Motobilt wheel-to-wheel LJ rockers during their Black Friday sale. They line up like they’re supposed to so now I’ve just go to get them painted and installed.
And now 10 months after bending the arms, it’s got a functioning rear sway bar finally. First time I’ve tried to use my mig welder at this house and it wasn’t happy at all. Ended up running it off of my big generator but got it done.
I knew having a sway bar back on it would make a difference but wasn’t expecting it to be as good as it is. I’ve been driving it without any since it’s been on the road and never thought it was that bad. Huge improvement everywhere but especially noticeable taking a hard left from a stop.
Got the rails cleaned up and the new fancy ones put in place over the weekend. I still need to triple check measurements and make sure it’s all squared up but it’s looking pretty good. Steering box looks like it should work although getting the ORI located around it might be a bit fun. It’s just clamped on the rail in the one pic and really needs to be forward at least a few inches but the stand under the rail is in the way. I originally was planning on trying to reuse the shock towers from the TJ frame but after staring at it for a bit I’m gonna do tube shock hoops. Motor mounts look like they’ll be fairly simple to make and I might ditch the lifted mounts to gain a little more clearance on the upper link. The Genright upper link mount should gain me a good bit of room around the top of the axle too.
Before I took it apart, I dumped the air charge out of the ORI’s and tried to stuff the axle to the frame to see how bad everything interfered. Drag link hit the tie-rod first so I removed it and swung the pitman arm out of the way. Next up was the pan hard bar that I thought would have hit the passenger frame rail first but it sandwiched itself between the diff cover and the balancer about a 1/2” before getting to the frame. After it was out of the way, the upper link tagged the driver side engine mount with about 1/4-1/2” left in the shock. Lowers were just about stuffed into the bottom of the rails at that point too.
The bumper on this thing isn’t made to fit an 8274 but I think I’ve got a solid plan to make that work. I did discover that a 9500i doesn’t fit either. Motor interferes with the passenger frame rail by a good bit. The xd9000 on my trailer measured almost 1 3/4” shorter than the 9500i so it might get to live on the Jeep for a minute. There’s also an old M8000 that needs a solenoid or two on the shelf that could end up on there.
I got after it again this morning on this pile. Motobilt front half is all welded out and I started mocking the axle and steering back up. The axle and box need to be a couple inches farther forward than they are right now but I’m out of threads in the links to spin them out any farther. I’ll dig out the old rear links from when it was a TJ and see if they’re long enough to mock it up. If not, I’ll be breaking out the square tube adapters and tacking some thin wall 2x2 to them to get it all dialed in. It’ll get 7075 aluminum from WOD to match the rear once I know how long they need to be.
It’ll turns out that there’s way more room around the back of the steering box where the ORI needs to be than I thought. The Motobilt frame never flares back out towards the front like the stock frame did so there’s tons of space there for the shock. I’m still planning on tube shock towers though. The steering box is most likely gonna end up sticking into the back of the grille shell and possibly even out the front.
Steering drag link and the panhard bar look like they’re going to package in there very nicely. The limiting factor for uptravel now is the lower links hitting the bottom of the frame and it looks like I can squeeze a straight bar in even stuffed that deep. A slight bend might end up needed but it’s looking good. I’ve got it mocked up with T-style steering right now because the passenger high steer arm is above the bottom of the frame rail at full bump. Pushing the axle forward a bit more might get that into where the frame kicks back up though.
