And so it begins....
Got the fuse panel almost done....
Sent from my DROID3 using Tapatalk
Reid came over and we got alot done...
Cooler mount/fans/firewall redone....
Cut the corners.....
Dash laid out...
Exhaust changed...
Got a new toy in the shop...
60 amp plamsa cutter and a circle cutter.
Hotdog guy and biggoofy came over and we cut out the sheet metal rear support and replaced it with 2x4x.25 tube and moved the rear spring perch to stretch the rear 5 inches.....
Had a flashback to the local auto transport guy- buddy had an old scrambler shipped in here from Az. and when the transport guy backed it off the trailer he left the axle loop on and said "here's your jeep". My buddy asked him if he wanted his axle loop back.
Got my new supercharger pulley from Branik motorsports. Got the rear axle moved and new shackles made of 3/8 cold rolled steel.
sent pony express
Got alot of stuff here today... got my motor back, tranny with new pan, battery box, firewall/cooler mounts and the grill.
I started putting the grill back together but had broke the headlight adjuster so had to hold up, but got the radi and fan and horn mounted and the hoodlatch back in. Got the fans and one of the coolers mounted.
sent pony express
Rock life pm what u need....
Got the motor, trans and tcase back in....
The rock sliders got built today thanks to jims garage.
sent pony express
I am enjoying your build-neat ideas and great parts list. Diggin' the color............ :)
Tonights progress... got the pulley installed on the supercharger and found a belt. Grill mounted and prewired. Winch mounted and fairlead..... started the inner fenders..
sent pony express
Holy bright green wide track Batman! Looking good! I am sure I read somewhere, but what engine is that there supercharger sitting on?
Went to olivers to drop off a few items, they already had the rear shaft done and the carrier bearing tacked in. The have 2 more shafts to make and gear it. I cannot say enough about Daves help this season. They had to turn down a yoke for the rear and are having a strap yoke converted to straps for the front output. Everything is 1350 joints and tight...
Sent from my DROID3 using Tapatalk 2
Stopped by today to drop off my diff cover from Barnes4wd. Dave has been busy getting the carrier welded in and the front shaft made(its waiting here to be balanced and painted)....
is it kosher to mount coolers/fans to the firewall like that? just wondering, if it is i wish i had thought of that
the whole build is awesome
