And so it begins....
I saw a picture of this thing today, looks like snappy has been busy! Looking good, snap. You're doing the old YJ justice.
Picked up the cage I picked up from GONOVRIT, had it sand blasted and gotg it set in tonight...
Got the front end striped out of the way and cut off the motor mounts, shock mounts and the track bar mount.
Looks sweet I hope my big ass fits lol
Me and the goof troop got a little done tonight... Got the rear in swaped to spring over with the 14bolt and the 39" stickies. We also got the tcase mounted up to the transfer case. Took a few hours to clean all the mounts off the 14 bolt.
Sent from my DROID3 using Tapatalk
We got a good bit done tonight! Motor is in and ready for mounts.
Bushings. The body lift is coming off so the drivetrain will be 3 more inches up in the body.
Going 3.5 or 3.4 pulley. Really depends on what the engine builder puts on it....
Went over to jims to help get the old stuff out of the way. We got the motor set in place and the axle close to its new home....
Is there a reason for choosing to do SOA vz SUA in the rear? to match the front height?
I am guessing that a traction bar in the rear will need to come at some point if it stays leaf spring?
Im sure you have thought it through, but if considering a traction bar for the rear, give me a shout as I have an idea that might work...
I think we figured out my belt issues....
I ordered an offset blower pulley that lines it up with the inner pulleys, then grabed a ps pump from a 98 camaro. I know my paint skills lack but does anyone see why this wouldn't work???
I will have to add an idealer pulley but everything is stock gm with the expection of the blower pulley....
Had a special delivery today...
Started on mounts for ps res and ps cooler and tranny cooler. The little coolers each get there own fans also.
