My wife wants a generator. I've been putting it off for years, we've never really been inconvenienced by an outage (been in the house for 10 years), but it would ease her storm anxiety so I guess it's time. Question is, how to decide between a whole home dedicated unit or a portable?
House is 2,400 sq. ft. Full basement, half garage half man cave/play room/guest room. Single HVAC, not sure on size off the top of my head. Heat is a dual mode system where it can run heat pump or propane. Gas log fireplace, gas stovetop, gas on demand water heater. No direct gas line, all fed from large propane tank. We're on a well. Plumbing in basement below grade so septic system has a lift pump to drain field.
200 amp service. Sub panel (50 amp) in garage that feeds welder and septic. It would be easy to plug generator in at welder socket and backfeed with generator sitting just outside garage doors.
I only remember the power being off more than an hour once since we've been here, and that was during the night, so like I said never been inconvenienced. My parents are a couple hundred yards away, on a different circuit, and their power goes off if a squirrel sneezes on the line and has been off for days at a time.
Whole home:
Pros
-always ready
-run everything
-no concerns about fuel storage unless we run out of propane
Cons:
-only helps me, where if we're good I could take the portable next door.
Portable:
Pros
-cheaper
Cons
-inconvenient
-fuel storage
-probably can't run full house at same time
If I go portable, I'm thinking predator 9K and I probably wouldn't be much over $1k for gen and setup.
So, what would you do?
Whole home:
Pros
-always ready
-run everything
Cons:
Portable:
Pros
-cheaper
Cons
-inconvenient
-fuel storage
