Biggoofy build thread 96 Jeep ZJ
Just read through this. Its looking awesome and came along way.
BTW I would like to see him say this to your face.
:shaking:
You got raped.
:shaking:
Thanks man and lol
Yes I do work at Montgomery motors.
Glad to hear man, congrats. You and me may finish our builds at the same time now haha
Seems u cant find zj info anywhere
Ive got a 93 zj limited with 4.0 aw4 and a np242
Right now its got 3.5" lift on 32s
Did you need rear long arms for your lift?
Im trying to lift mine to 5.25" of lift so any info on what relocation brackets/ fab , long arms I need would be apperciated
Sry for hi jacking your thread
Sent from my HTC Glacier using Tapatalk
Go search around on mallcrawlin.com tons of Zj info. For 5"+ of lift front long arms are needed but you can use adj short arms in the rear.
Did final assembly on the 9" tonight's and bolted it in!!! I'll be getting new grade 8 bolts for everything Monday so I just used the old stuff tonight. I have to make new upper coil buckets tomorrow then the rear springs can go in. I'm also going to be moving the upper shock mounts.
Great meeting you to man! That plate was perfect.
The rear is now under its own weight. I made my new upper coil buckets and then set in the coils.
Thanks a bunch man.
Got a good list to do this weekend!!
Move the rear upper shock mounts
make brake lines
fill diff
Ill be ordering drive shafts from Oliver's driveshafts on Monday or Tuesday along with the 7/8 steering from ruff stuff then all I need to do is wrap up a few small details and she will be done!!!!!!!!
http://www.ruffstuffspecialties.com...tuff&Product_Code=78STEER&Category_Code=STEER
I also need to build my hp44 lol
Didn't really get shit done this weekend but I picked up my hp44 from getting geared and hopefully I'll have it all installed this weekend. I started to install the 5 point harnesses tonight need to figure out lap belt mounts and anti sub mounts.
Sure are 79 f250 front and 9" rear
Getting the f250 knuckles freshened up and ready to go on. Hopefully have the front end done and on its own weight in about 2 weeks.
You and me both man!!
Comp cut started.
Ruff stuff 7/8 heim steering kit is ordered now all I have left to order is drive shafts.
I can't wait man I'm ready to go wheeling!!
Looking good man, can't wait to see it on the trail.
Hp44 brackets came today!!! Thanks to Greg at Frobot fab for the awesome products.
Tonight I finished up cleaning the tubes on the hp44 and began welding up the brackets!!! Won't be long now!!
