So the dash is in, cage is bolted down, I left the gauge wiring until after the drivetrain is back in. I have made some (slow) progress.
Got the front axle back in, so the truck is back sitting on the front tires atleast.
Not exactly sure how heavy a D60 front is, but it seems twice as heavy using a moving dolly and plywood to put it back in.
Then the MIG decided to break again, so that slowed me down for a few weeks...but the good news is it got replaced with a HH 210.
With the new welder I finally got around to finishing my steering arm. I had been putting this off forever because I really didn't want to stick it. The draglink heim was maxing out with the suspension travel, mainly b/c the Rockstomper arm I have is just a flat piece of 3/4". Instead of spending $$ on a new arm with a milled surface I decided to make this one work. I drilled a hole at 17 deg (the drill press was not happy me that day!) and then ran a sleeve through and then add the double shear bracket back on at the proper angle.
Then put in a piece of scrap 1/4" for good measure.
Also got some work done on the rear axle, was hoping to have it complete and back under the truck this weekend, but I guess that was a little optimistic. I spent forever ditching the drums and working on getting it converted to disks.
Check out what 3" backspaced wheels and big drums can do on rocks. Both sides had multiple chunks taken out at the lip.
