ghost
- May 25, 2006
- Hartsville/Camden,SC
I think 95 was the last years of the manual.... The ZJ had them in them around then too.
93 only and only behind the 4.0I think 95 was the last years of the manual.... The ZJ had them in them around then too.
Anyone in the area that could check this out for me? Hard to tell by the color if there's any rust or anything. I'm interested in it, have had 3 2doors but never a Manuel!![]()
*EXTREMELY RARE* 1995 Chevrolet 2 Door Tahoe 4X4, 5-SPEED Manual...
- *EXTREMELY RARE* 5 Speed Manual Transmission - Horsepower: 200 hp - Towing capacity: 7,000 lbs - Engine: 5.7 L V8 - Four Wheel Drive - Miles: 210K - Rebuilt transmission - Runs great - Location:...raleigh.craigslist.org
Someone needs a 4wd, 2dr Tahoe with 3 pedals! I have never seen one of these with a stick shift in the wild.
Looks like something @DonYukon should add to his stable.
I thought it was 93 and 94 actually. I know after 97 the xj manual gets scarce.93 only and only behind the 4.0
Its probably not but that shifter looks like a NV4500 shifter.Anyone in the area that could check this out for me? Hard to tell by the color if there's any rust or anything. I'm interested in it, have had 3 2doors but never a Manuel!
Charlotte.craigslist.orgWhat do you guys use to search craigslist? The app I have on my phone sucks major donkey dong.
www.searchtempest.com is what I use if the nearby areas isn't a wide enough area. Key is to use the "-" with specific words to eliminate all the friggin spammers who put a billion keywords. For example if you put -dieselofhouston it will remove all results from those spammy asshats.Wasn't there a site that would search multiple craigslist cities? or was that replaced with the more from nearby at the bottom of a search?
It looks like the engine is missingDon't really know much about mountain bikes, but I'm kinda sorta in the market. Is this a good deal or no?
KONA KIKAPU FULL-SUSPENSION ALUMINUM MOUNTAIN BIKE - bicycles - by...
KONA KIKAPU FULL-SUSPENSION ALUMINUM MOUNTAIN BIKE, LARGE GOOD CONDITION 1x9 SRAM X-9 SHIFTER AND REAR DERAILLEUR SHIMANO CRANKSET RACE FACE CHAINRING HAYES STROKER TRAIL BRAKES HYDRAULIC DISC...charlotte.craigslist.org
Not bad. If you do a lot of climbing, the rear suspension will probably bounce a lot and eat up a lot of efficiency. Pretty nice build kit for its time, which is probably mid-2000's. I personally really like bikes from that era and earlier. Only thing I see that might be problematic is the 1x9 drivetrain (1 front chainring and 9 rear chainrings/gears). Most of the newer 1x bikes have a smaller front chainring and a much larger rear cog (40-50 teeth), whereas that one looks to be in the neighborhood of 30 tooth front and 34 tooth rear. Basically what that means is your lowest gear isn't that low, around 1.1:1. When I was in good shape, I never used the small chainring up front, and rode everything around in the middle ring on the front (around 30 teeth) and the big ring on the rear (34 teeth on mine). But for long hills in the mountains or now that I'm fat and lazy, that wouldn't cut it. If you wanted to swap the rear cassette out to a bigger unit you'd need a shifter with different throw, and the derailleur likely doesn't have enough travel, which means you would have to replace the cassette, derailleur, and shifter (and that's only if the hub is wide enough to accept the new cassette and there are no clearance issues). My current bike (which I just listed for sale last night actually) is a 2x10 with a 24/38t front and 11-36t rear for gearing range of 1.5:1 in low and 1:3.5 in the highest gear.Don't really know much about mountain bikes, but I'm kinda sorta in the market. Is this a good deal or no?
Pretty sure you only need that cart/table if you didn't pull out.I don't know why I need this, but I need this. The pullout table is tits.![]()
Baby cubby/cabinet - antiques - by owner - collectibles sale
Vintage baby cubby/cabinet the hospitals used. Do not have the plaid tub for the top. This piece is in pristine condition. Can be used for a tool cart! Have several used for that!charlotte.craigslist.org
