Original motor, new injectors. All cyl are near 500psi (there is a post listing the specifics from last week). New Fuel filters, new lines. New batteries (cooked one of the old ones) Both, rated at more than factory CCA. I charge them both overnight after a long day of cranking.
How are those functions related?
Galen - is it getting air? Would be pretty easy to pull the rubber hose at the intake horn and see that it's sucking in... That's a long shot tho.
I'm betting the pump isn't generating enough pressure to break past the pop-off pressure on the injectors and fire them.
When I pull the fuel line bolt at the injector back (exposing the connection) and crank, it will squirt fuel on the underside of the hood...
damn I'm good. Water in the grease will trash one of those pumps.Injection pump
Problem found...
Took the injector pump over to Diesel Injection of Cary...Several hours of teardown...($$$) Govenor is held together with duct tape...Plungers shot...Cam worn...
"Looks like this pump has 1/2 million miles on it"
Looks like it's cost prohibitive to rebuild.
Good to hear but it sucks!!!! You now know the cause... You going to use the other pump?
Jon
How much is a rebuild on a P pump at DIS?
Seems like Ken was saying it wouldn't be too bad for a VE pump (first gen)
Bolted it all up, bled, bled, bled. And if fired almost right a way. Had major leak issues from several of the injector hold downs, and some leaks from the fuel line nuts. Still chasing what looks like a hold down on the #6 (whooo, hooo....Gotta pull all the fuel lines and return line for that one). But, it runs like a scalded dog now. I've had it up to northern VA, pullled to URE twice and run it back and forth to Lewisburg a hundered times...It's doing well.
How deep has Keith gone with his truck ? he messed with it yet ?
