77GreenMachine
Phillip Talton
- Mar 30, 2010
- Trinity, NC
So I’m in need of a 31 spline Big bearing 9” carrier if anyone close by has one.
But it did not break the 3rd luckily.
@02gmc5.3 has a 9 inch axle. Pretty sure I saw it in the weeds up there a few weeks ago.So I’m in need of a 31 spline Big bearing 9” carrier if anyone close by has one.
Philip could probably find a cheap carrier and get the 9 inch back together and sell it for what he would have in a 14 bolt swap.14 bolt...
14 bolt...
Would a chromoly shaft have helped or where you running them already?
No it was a stock 31 spline. Honestly, even a 14B Chromo shaft, Dana 70 or anything would have broke they way I did it. All the weight on 1 tire dropping down on the rev limiter like that. I know several people who have done the exact same thing in the same spot. It’s a recipe for breakage if you do it wrong (like I did).
For now, I’ll throw a stock shaft back in it but may add Chromos later since they’re no too expensive. The rear has held up to some real beatings so far. The front has Chromos with Yukon Super Joints.
I bet a Dana 80 would have been just fine... I could have made you a deal on one
FWIW, ICON runs AX15s behind most of their FJs and I think the Broncos too. I asked him one time about it on Instagram (I think) to which he replied that people are overly concerned about the strength of them and that they have held up fine on all his LS builds.So the Jeep is still sitting in my garage collecting dust and many other things, waiting to get my third member back and I’ll throw it back together.
I’ve been lightly thinking about a 4.8LS swap but would like to keep the manual transmission. AX15 behind a 4.8 would hold up just okay, it would be risky, but it’s pretty expensive to make it match up. It’d be easier to get an S10 tranny or something of the like. I do not want a 465, I’m not a fan. What other options are there?
I highly doubt I would do this, as I intend to sell this Jeep within 2 years but I’ve tossed the idea around because from time to time I run across 4.8s pretty cheap and I think if I can get a cheap manual trans and keep my transfer case it would be a fairly cheap swap but I’m mostly just brain storming.
What manual trans options to I have that would keep things real simple?
Easily avoidable if you drive with some sense.
That might be a challenge
