Nissanwheeler
Active Member
- Sep 4, 2010
- kannapolis NC
Ok so Ive been working on this truck since i was 15. the truck was given to me by my pawpaw when he passed away. After i turned 16 i took out to play in the mud and after getting stuck twice i knew i wanted bigger tires and a lift. It started out as a 3" suspension lift and a 2 weeks before i was scheduled at Galloways to get it put on i decide 3"s wasnt enough so i bought a 3" body lift as well. I had done my research and i figured id be fine for some light wheeling. Man was i wrong. After my first trip to Uwharrie i was hooked. The trip ended in me bending a tie rod on the dutch john trail. i didnt think much about it i just replacled the tie rod and went on. But my second trip also ended in the bending of the same tie rod but on Dickey bell. This is when i started to re-think about the suspension. After replacing the tie rod i put a couple miles on the truck and i noticed the play in the steering and the slight camber issue. To replace all the parts it was gonna cost to much for me to keep replacing it every time i went wheeling and thats when i started looking at the SAS option. After a while of driving on the bad steering and ball joints it got to where i couldnt drive it any more so i knew it was SAS time.
A little about the truck.
1994 Nissan Hardbody (d21)
V6
4x4
Custom tube power coated bumpers
3" body lift
3" suspension lift
35 Mickey Tompson MTZ baja
Plans for front:
dana 44
calmini front hanger
calmini through frame shackles
waggy 4" lift inch leaf springs
4.88s or 5.13s havent decided
spartan locker
Plans for rear(eventually)
14 bolt
4.88s or 5.13s
arb locker or powertraxx
Tires:
37s or 38s
steel bullet hole wheels with a red beadlock
Time for some pics.
stock:
(sorry i dont know how to resize them)
heres one befor i cut her up
reason for SAS
tearing apart dana 44
ditching the IFS
after torching the brackets and cutting holes for shackles
V6
4x4
3" body lift
3" suspension lift
Plans for front:
dana 44
spartan locker
14 bolt
4.88s or 5.13s
Tires:
37s or 38s
Time for some pics.
stock:
reason for SAS
ditching the IFS
looks good, I like how you built that winch bumper
, the welding is complete.
