marty79
- Nov 24, 2013
- Newton, NC
Hey everyone looking into buying this and just wondering if this kit is all I need to complete the tie rod...bolts? Inserts once I drill it? And this mounts on top of steering arms correct? (Never used heim stuff), thank you.
You will need to drill your arms to a 5/8" hole to use this kit. You will receive:
Would this kit for $131.00 be a better buy?
You will receive:
1 - RH 3/4" X 3/4" Heat Treated Chromoly Heims
1 - LH 3/4" X 3/4" Heat Treated Chromoly Heims
1 - RH 3/4" X 5/8" Heat Treated Chromoly Heims
1 - LH 3/4" X 5/8" Heat Treated Chromoly Heims
- 1 - RH 3/4" X 3/4" Bore Heat Treated Chromoly Heims
- 1 - LH 3/4" X 3/4" Bore Heat Treated Chromoly Heims
- 1 - RH 3/4" Hex Head Tube Adapters (1" Tube ID)
- 1 - LH 3/4" Hex Head Tube Adapters (1" Tube ID)
- 1 - RH 3/4" Jam Nuts
- 1 - LH 3/4" Jam Nuts
- 4 - Safety Washers
- 1 - 1.5" X .25 X 54" DOM tube
You will receive:
- 2 - RH 3/4" Hex Head Tube Adapters (1" Tube ID)
- 2 - LH 3/4" Hex Head Tube Adapters (1" Tube ID)
- 2 - RH 3/4" Jam Nuts
- 2 - LH 3/4" Jam Nuts
- 2 - 3/4" X 5/8" RS Stainless Safety Misalignment
- 2 - 3/4" X 5/8" RS Stainless High Misalignment
