Fabrik8
Overcomplicator
- May 27, 2015
- Huntersville
What's this?
Your first post had a link to safety washers. I'm assuming your Barnes kit probably comes with them too, but I would check.
When you have a Heim in single shear like the picture below, the (bright silver colored) safety washer prevents the Heim housing from slipping right over the bolt head if the Heim fails and the Heim housing pops off of the Heim ball or the race comes free from the housing.
You don't need this in double shear, because the parts of the mating joint would capture the Heim housing as they are already on both sides of the Heim.
So don't do this, where there is no safety washer. Notice the Heim housing could slip right over the bolt head if the ball popped free or the race came out of the housing. There goes the tie rod, free to roam around wherever it wants.
These 7/8 are the ball bearing ones so isn't that better along with being 7/8 size?
Heims are a spherical ball (with a hole through it) inside a spherical race. A single, big ball bearing basically. They are all like that.
