Loganwayne
#BTL
- Feb 15, 2013
- Clyde, North Carolina
Up travelIts flexed out already
Ok so go with original Z bar I was making!! Good to know others have done itZ-links like you built are very common with the Samurai SPOA crowd. The biggest down side with them is bump steer. Overbuild the heck out of it, check clearance in all situations and roll out.
So this is what it would have to be if this way can work
WTH is so hard to understand about just buying a high steer arm and the appropriate knuckle.
That will safely and adequately fix every single issue you speak of.
I hear ya bud..100 high steer arm plus what...80min to drill this knuckle..and this axle is maybe worth 100-150 so I don't see reasoning personally...WTH is so hard to understand about just buying a high steer arm and the appropriate knuckle.
Edit: You already have a passenger side flat top knuckle. All you need is some easy machine work and a $100 arm with studs.
John, this is a really easy fix.
And sell if for 450That's the entire reason to do that. The axle was practically free, and going the rest of the way for the best-practice solution costs almost nothing as well. By your math, you'd end up with $200-250 for a complete high steer axle. I can definitely see the reasoning there....
Its ok its done..I did original Z bar as Drkelly said and be done with it..
Someone would people look for 44s all the time having high steer would make it more sale able. I considered getting a set of 44s and building them for a rig designed for 37s they would save me a couple inches of ground clearanceAs you should, if someone will buy it.![]()
Ohh boy had a feeling y'all would want to lol lol...here it isWe wanna see the pics of the finished product
Low pinion d44, pass side, now welded spiders , 3:73 even with high steer nobody wants lol except ....ahh(yes my dumb butt)heheThat's the entire reason to do that. The axle was practically free, and going the rest of the way for the best-practice solution costs almost nothing as well. By your math, you'd end up with $200-250 for a complete high steer axle. I can definitely see the reasoning there....
If u tell me its gonna break...too bad! Lol, I'm running it. That drag link breaks and I will pay someone to make a freaking draglink no matter the stupid cost...argh what a day
Why in the fuck is there an adjustment collar welded in the middle of the drag link?
Geez noob, so you can continually re-enter the steering wheel...for obvious reasons.Why in the fuck is there an adjustment collar welded in the middle of the drag link?
What's it look like at full stuff? I have $50 says the drag link hits the tie rod.
So I can do alignment...Why in the fuck is there an adjustment collar welded in the middle of the drag link?
And so the answer is still "its crap" lol
I don't need lessons on how to ailing a jeep thank u. I left the drag link sleeve for simplicity of centering steering wheel when adjusting lift in future..nothing wrong with that, just my preferenceIf "centering the steering wheel" and "alignment" are the same thing...?
Soooo it did not occur that threaded rod ends can be used for the same purpose, and is the reason that a male thread is used at one side of a tie rod, and a female threaded rod end at the other? Break the (rod end) jam nuts free, and rotate the tie rod to increase or decrease the center-to-center length. In your case, you'll want to stick to nice 90degree increments for obvious reasons of using square tubing.
I suppose it's too late to say that you want to calculate your link lengths with the rod ends close-ish to the middle of their adjustment range, else you have no adjustment range.
