- Mar 16, 2005
- Archer Lodge
The gears have been installed since July with zero issues at all. Same vibe it always had after being lifted, just at a lower vehicle speed.
Now it's totally different.
I wasn't clear earlier.
The vibes are totally different now with the SYE and DC shaft. Before (with 3.73 as well as current 4.56) it was a run of the mill lifted Jeep driveline chatter. Same as my mildly lifted 01 XJ. Tip in throttle, floating throttle vibe. Nothing to sweat.
Now with the SYE and DC shaft, it's literally like riding on rumblestrips from 55-60. Not throttle sensitive, not Accel/decel related.
Once you hit that speed range, the vibes come alive.
No side to side play. Dave at Oliver's has already sent me a second one, just in case, with no real change. This was a couple weeks ago.No play side to side at all in the driveshaft right? Have you got another shaft to throw in there and try for the time being?
My front shaft will interchange as well. Swapped it to the rear with no noticeable difference either.
have good success with the IRO kit. On an XJ application the output shaft is cut shorter to allow use of an XJ front shaft in the rear. This is what got me thinking thisnmay be a solution to my issue.You tell me?
It does. I verified it the last time messed with it. Last time, I added some rtv to further dampen itI guess if that's what you've got to work with, it'll do
So does the rear output flange seat up against the end of the output shaft or no?
The ZJ front shaft is about 2" longer than an XJ one. So you only cut about an inch off the rear output. Doing so gives you a lot of spline engagement but I'm thinking that is the issue.I didnt mention this earlier, but your comment about shortening the replacement yoke made me think of it. I did cut the output shaft to the minimum Iron rock recomend, then had to cut the yoke to fit.
Maybe that would help on the zj? Not sure if the driveshaft you have would still work.
I’m not an IRO fanboy. I’m an Ironman4x4fab fanboy for sure!
That much engagement also allows for the weight of the rear shaft to lever against the yoke. My vibe is really like a very heavy resonance. Resonances are always due to looseness and/or cylindrical issues.
I'm going to cut the yoke so I only have like 1-1.25" of spline engagement.
My wife rarely even uses 4wd so strength isn't an issue in this case.
We'll see tomorrow afternoon if it helps...
IIRC iron rock recomend a minimum of 1.25" of splines left on the output shaft, that's what I cut mine down to.
Not sure if that would matter with the wife's zj, as you said strength isnt an issue.
I appreciate everyone's responses. I'll update as we figure this one out
Hurry up. This is like a lotto draw where you are holding out like forever on announcing the last number.![]()
Can you clarify a few things for me? They may have already been stated but I've found myself lost in all the comments.
1) The output shaft of the TC is cut square
2) The output shaft bottoms out in the yoke
3) The taped hole is concentric and square with the output shaft
4) The hole for mounting the yoke to the output shaft is concentric with the yoke
With the yoke installed on the output shaft (no driveshaft), what's the run out? What's the run out with the driveshaft installed?
