adamk
- Nov 20, 2010
- Hot-As-Hell, TX
1) The output shaft of the TC is cut square Without a doubt
2) The output shaft bottoms out in the yoke Definitely
3) The taped hole is concentric and square with the output shaft Yup
4) The hole for mounting the yoke to the output shaft is concentric with the yoke 'Tis indeed my friend
With the yoke installed on the output shaft (no driveshaft), what's the run out? What's the run out with the driveshaft installed? Haven't checked yet. I plan to this afternoon when I get time.
I drove it to work today and paid close attention to everything. It's smooth as glass up to 50. Then you can just start to feel and hear the resonance begin. It gradually gets louder and more noticeable and from 56-60 is unbearable. At 61, it all but goes away. When it's doing it, you can feel the resonance in the e brake handle but not the transmission shifter. You *can* feel it a little in the transfer case shifter. It's bad enough to cause the image in the rear view mirror to be completely distorted. It really feels like driving on the rumble strips.
Tip in and tip out of throttle has no bearing on it. This absolutely rules out anything in the differential(s). Placing it in neutral doesn't change anything either. That essentially rules out driveline angle.
I'm really thinking it is something with the IRO adapter yoke. Maybe it's loose on the splines just enough under just the right load conditions to chatter.
Dumb question but did you drill and tap the hole deep enough so that the bolt fully torques down on the yoke?
. When I said "still vibes 55-58, nothing she can't deal with", that wasn't accurate. I don't blame her. It's annoying as heck to drive.
