Just a simple Sami buggy
untchabl
I like rocks
Bear Creek, NC 27207
Decided to start a build thread for my little project. Been collecting parts and working on it for a few months now and starting to see some progress.
First of all, I want to say a huge thanks to Jason (@DirkaDirka875) for letting me take over his shop so he can help me with all the chassis fabrication.
Goals for the build
- simple 2-seater trail rig
- 106-108" wheelbase
- Tracker 2.0 engine & 4-speed transmission with Tracker/Toyota doubler
- 4-linked front and rear on Toyota axles with air shocks
Let's start at the beginning, this whole project started because the wife totaled our little knock-around 99 Tracker. I had been wanting another trail rig since our Wildcat just wasn't the same as a real buggy. So the Tracker made a perfect drivetrain donor.
Here is the Tracker after the wreck.
index.php
With the drivetrain sorted out, I found a rough Samurai body on Craigslist and stripped it down and pieces started falling off.
index.php
index.php
Built a frame out of 2"x4" .120 (the angle iron is just to keep it square)
index.php
index.php
index.php
Next up, chassis fab...
Turning a tub upside down to attach a subframe to is one neat trick I never would've thought of. :smokin:
On those mounts where they attach to the sheet metal, is that a two sided plate that's thru bolted and welded or just welded?
The plates are only on the bottom and just welded to the sheet metal. The tub isn't going to be structural. Only thing that will be mounted to it is the pedals, brake booster and the auto shifter. Everything else will be mounted on the chassis, including the seats.
I dig it! I'd love to build me a Sami buggy at some point. Just curious about the seat mounting with the single tube under the front of the seat. I like it just not sure about it. Is that the final product on them?
Other than capping off the open ends of the tube and finish welding, the seat mounts are done. The single tube goes straight down to the top of the frame rails. I don't see them being an issue but I'm no expert so I welcome input from others.
Maybe tie the front of the seats together with a tube across the trans tunnel. They probably will be fine but that would keep them from moving more than what you have now
Looks awesome. I remember you telling me about this when I bought those 2 tires from you. I'd like to think I've supported this build! :D Just kidding. Awesome work. I wish I had that talent and equipment. Looking forward to seeing it on the trails.
Man that looks good! Can I drop mine off!? :D
Not sure if you'll want to do that. It won't cost you an arm or leg but how about a finger? o_O
@DirkaDirka875 had a little accident several weeks ago while we were working on the buggy. He's all healed up now and back at it again.
My buggy has been named "Just the Tip" by several wheeling buddies after this.
index.php
ouch! glad that healed up good. Scars are like Tattoos with better stories..
Pulled out the mock-up drivetrain and installed the real one today.
index.php
index.php
Figured out the stock transmission tunnel wasn't going to work with the way we want to mount the transmission shifter, so we cut it out. We'll clean it up and make a new tunnel once we finish the rest of the cutting necessary to mount the t-case and keep a flat belly.
index.php
index.php
Got the driver side door bar started. Next time we'll do the passenger side and start on the dash.
index.php
index.php
Found out the fuel cell I've got isn't going to work out the way we want to so I ordered another one this evening. Hopefully it will be here by the end of the week so we can build the mounts next Monday. Every work day we move one step closer to getting it out of Jason's shop and ready to come home.
Had another good work day yesterday. New fuel cell came in last week so we added more tube to the rear and built a mount. Just need to add a couple small pieces of tube for the Swag Action Packer mount and the NextVenture Canyon cooler mount then the rear is done.
index.php
index.php
index.php
index.php
We also got the door bars finished and started on the dash. Dash is going to be simple flat aluminum panels. A tablet with the Torque app is going to be used for gauges. Going to order an orbital mounted steering column this week.
index.php
index.php
index.php
