EasySteve
- Mar 20, 2005
- kernersville
Michael is getting married today and then hes off to Mexico for a few days. This is probably not on his mind...
...are the joints in the airshocks going to allow enought movement side to side as the axle flexs?...
How's the baby doing?My plans are the competition at URE, maybe a comp or two here on the east coast if time ever permits as well.
If I remember right you were running it transverse. Why not run a divorced 205 vertical for lower gearing?Couple more, 2nd one is of the engine/turbo piping/intercooler.
I plan to get a 16 valve head to put on it. The 8 valve I have has 70 HP, 16 valve has 102HP.
If I can find a 16 valve from a D16 (1.6L) then that would boost the HP a little more (rais compression).
Also looking for a Civic EX transmisson because I think the ~12MPH in 1st gear is going to be a little too fast for even the easiest crawling... EX transmission should be able ~5mph @ 3500rpm's, still going to be quick, but hopefully I can manage and not have to put a slushbox in it.
