it dosent matter, coolant has rust inhibitor in it. as long as you dont run straight water its cool
Thats a hell of a good idea, hot rodders have done much the same for years. Engine block castings however by nature do inhibit "some" rust since thay have a higher carbon content. The better the cast the more carbon, silicon, and graphite are intermingled into the casting. All non oxidizing elements.CrawlWerks you're killing me. This thing will be in the scrap yard before that's a problem.
They don't make engine blocks out of rustable materials?
I'd think your biggest issue is going to be cavitation or air locking the system.
You going to run a racing style 12 volt pump or standard belt driven system?
You might be able to pressurize or vac. fill the system like on newer cars where the filler has to be remotely mounted do to space restrictions. Your going to have a huge capacity and alot of welds to check out pre fill up!
Bout time to make that digger dig.... Yall got the sofft compound tires or the hard ones
About time some work got done on this thing. Looks good; it's amazing what a CNC plasma can do![]()
Sheet...I free hand that.
when are you going to start your winning 2012 KOH buggy at this rate?
looks good guys!
you would think ya'll were hand extruding the tubing as well as long as its taking ya'll to finish this thing, hurry up!
looks good guys!
You ready to buy a rig yet?
looks like its laser cut?![]()
