skyhighZJ
- May 31, 2012
- Aberdeen, NC.
This used to be the 4406 chassis and has been raced all over including KoH. As it sits now it needs the front half of the cage built as it was chopped for a rework/ LS swap that never happened. THERE IS NO WIRING OR PLUMBING. Asking $4,500 FIRM
Parts included with sale:
-Chevy Dana 60 KP front Cro-Mo shafts and Yukon Hardcore lockouts. Has one Yukon ujoint and one spicer solid core.
-PSC Full hydro double ended ram
-orbital mounted with quick detach steering wheel.
- DOM Links front and rear
-Chevy 14bolt rear
-Currie anti rock on the rear
-203/205 Doubler setup using an ORD box 3 sticks
-no driveshafts
-Frame mounted stub shaft for better front driveline angle.
-Chevy LT1 w/“thinned” harness and computer has PSC pump mounted. PSC remote resi
-Rebuilt RVMB TH400 w/ new torque converter. Has sat in a garage for about 8 yrs so would recommend it be opened up and looked at.
-Winters trans shifter
-Derale trans cooler w/fan and thermostat switch
-extra derale cooler panel for steering or oil cooler option.
-fuel cell. Unsure of brand but it’s a metal tank with a bladder and foam. Older but never used.
-old and crusty 39” reds on 17” race lines x4
-aluminum fan shroud with dual electric fans brand unknown
-old FOA coilovers (probably no good and only have springs for one shock)
-old Fox Air shocks (need gone through but straight and chrome is good on shafts)
Probably more parts that I’ve gathered and forgotten about.
These are the pictures I have right now but can get more upon request.
-Chevy 14bolt rear
-no driveshafts
