pitbullcruiser
- Apr 14, 2010
- Longmont, CO
Nice, no turning back now
Thanks man. That's right. It's really no turning back...I cut off my shoc k mounts. Lol. Took the criss member behind the seats out and cleaned the frame. Got to weld the pass side on... Just cause I had it ready and it was too late to make so much noise with the grinder. But tomorrow will bring much more grinding. And hopefully get more work done. It turned out nice so far. I'm excited to see how it does.Nice, no turning back now
Thanks man. Gotta roll on this thing. It's coming together slowly. But I have 10 days so I think I'm Stoll good. It's going to be tight but it'll be fine.Lookin good buddy
That's probably a negative ghost rider. How about y'all all come over and help me get this pos going ?!?!?!?!?!Next Sunday testing ?
Hey how much uptravel are you running on your air shox? And how much oil vs nitro ?I'm at 220cc right now of oil and going to stsrt with 200 psi of nitro. I'm going to bring a tank tho to tune until I get it right. Just curious?Why did you decide to put the lower link at the axle way above the center line of the axle?
Really. I didn't think that would be too much. I'm light in the rear but not too light. But I havent tuned airshox before. I was just basing my numbers off of other builds and weight.sI like to run half up and half down if possible. With air shocks, you get less "push" by running them with little shaft showing, because the pressures are lower. The more oil over recommended you run, the harsher the ride will be and the more air makes them more bouncy.
Those numbers re probly close to start with, but I bet it will be too much pressure.
Yea. What he said.I suggested doing it that way because Jonathan seems to always get crossed up in a ditch or a gulley. It's not the norm, but I think it will help judging by how he drives. I doubt he'll be competing for a holeshot anytime soon. My thought on it is the truck will work better when it's crossed up rather than level at static.
Once you get to tuning the shocks you'll be surprised at how completely irrelevant the recommended factory settings are. Especially in lighter weight rigs. With the recommended amount of oil and air in mine in the Xtra cab it rode like crap and it liked to "push" or unload a lot on dropoffs. Once I dropped the PSI and oil a bit (numbers I cant remember after 2+ years) It rode a ton better and didnt unload or lift awkwardly on drops. Take a jug of oil, a syringe or measuring device and your air tank. You'll probably end up wanting to change oil and air at some point.
I came up with that as my start for my valving and my weight of my buggy. The valving 40/90 so I'll start with a minimum of 210cc and move up for ride and psi for ride eight and will adjust from there. I'll be tuning for sure, but this is just my start..
Where did you come up with 220cc? I have not thought about tuning my shocks in a long time, but I do have a nasty unloading issue going downhill and turning sharp (like a switch back).
