RobMcBee
Slow n easy when you're not gettin greasy....
- Jan 12, 2009
- Fort Mill / Indian Land SC
sweet! Like the spokes! I got an old radio flyer in the garage that's gonna get a resto mod one day....
I'd assume that if they're for a park (even if private) that they would have a PE stamp on them since they are a load bearing device for carrying human traffic. If so, call that guy and ask. Then again, I'd assume they would use I or H beams or box tubing instead of channel if it were PE'd.View attachment 145181 View attachment 145182
20 ft clear span foot bridge. We are almost don with the metal fab. We are putting treated, lightly stained decking on it with hand rail accents of wood down the whole length. We were shooting for a train trestle appearance like you see on the Virginia Creeper Trail. We are pretty certain about building two more smaller more detailed bridges for a small private park. I wish I had enough engineering back ground to figure how much load these things could handle. Guess I should have stayed in the engineering program instead of jumping full bore on welding and machining.
We boxed the ends with 3/16 plate with a broke out angle on the bottom. These also will be the anchor points for the concrete piers it rest on. The piers are about 3 ft each so the open span is around 14 ft I guess. No degrees in design or engineering here, just plain ole country boy sense. I've built and repaired trailers with less, which does load differently but handled a whole lot more weight and stress. I was just curious what she would actually hold. The real kicker is the owner is only spanning a spot about 36-40 inches deep! We stayed away from tubing on the frame for corrosion since its getting a bunch of holes in it, and my partner thought jr. H beams (my idea) was overkill.lateral bracing, imagine what happens when you squeeze a hard taco shell. Not trying to insult, just chat. Could cope some angle to span from channel to channel at the top flanges and get some ridgidity
I built a popsicle bridge for high school that held over 20 text books. Does that count??
Awesome!
Nice! I built a shop couch out of the bench seat from my Ford. My father in law has been "borrowing" my welder for months so I had to temporarily build the frame out of wood, but will be welding it up to bring it up a little higher and maybe add armrests when I get it back. I put mine on casters to roll it around the garage easily.I threw together a cool shop couch the other day out of an old chevy bench seat.
