Random pic thread.
I had No Idea! Few years back, & cleared & trimmed some overgrown yard area, for my neighbor. Through a friend, I ended up with a Large Bobcat, enclosed cab, & 4 n 1 bucket. Really nice in the Summer heat! I scrapped everything needing it, ripped up some bushes, & even yanked up some small trees, with the 4 n 1 bucket! Wisteria covered part of his lower yard, & he complained about trying to cut grass, over it. I'm talking about Vines, running on top of the ground. No more that 1/2 to 3/4 ". My god, No. Them damn things Stalled the Bobcat! Only broke a few of them, but couldn't plow them out. I gave it up!
Seems so close...but hanging sheetrock is about the halfway point, timewise. Finish work is slow going.
If I could get any client to think that I'd be happy. Had a guy pissed Friday because we can't install his appliances until mid August even though they were ordered in December. Had to call supplier on speaker phone with him and he then lost his shit when she said she didn't have them scheduled for delivery to her unit the 10th
It’s the devil. Hence the plan to get a mini x in here.
Saw this a couple of days ago at the local Dolla Gentral .......
Look at all the badges REAL close ......
I talked to the guy ..... the one over the marker light is legit!
I always thought that square body and the Ralley type wheels made a good lookin' combo.
Seems slightly familiar for some reason minus about 149 cubes
Bought this todrive a couple months back while waiting for a tranny for the 2500.
Thats a good idea. I already put a screen and a hat over it, but since it is literally just PVC gutter material thats easy too.
I just find it baffling they just leave it open like that.
muh fuggas did the same thing with mine. Only saving grace here is that since they 'knew' the area has 'high radon,' they built it into the house as it was being built. Started as a passive system, pipe coming out of the ground through the slab in the basement floor, up between the walls and out the roof... you guessed it - open upwards. Not sure how that passes as a 'passive radon system.' Of course, it tested higher than the 3 pCi/L, so the warden "had to have" an active fan installed. So some dooder climbed up into the attic, hacked a hunk out of the PVC and stuck a fan in it, finding some random wiring up there to splice into. Still didn't cover the top.
Fast forward to when we had a storm (not the one y'all are referencing, thank gawd) and it blew the shingles loose on the roof around the boot jacks for the plumbing and radon vents....had both of them leak. I get my happy asses on the phone to make a warranty claim...tell them that when it rains, it's leaking. I can hear the water tapping on the drywall on the ceiling. Their response: "How do you know it's leaking? Often times, water drips down the inside of the pipe and makes that sound." Had to explain literally three times that water was coming through a screw hole holding the drywall to the joist, and making puddles in my carpet....water was tapping against the drywall because I moved the insulation so it would dry out....my buckets wouldn't fit under the pipe joint...etc. etc.
Had one stuck in the screen about a month ago. I kept hearing this crazy buzzing and couldn’t figure it out. Finally saw little dude. I just poke his nose and he flew away. Another one was hovering by him the entire time he was stuck. Must have been laughing or giving him the “I told you so”.
