WARRIORWELDING
Owner opperator Of WarriorWelding LLC.
- Jan 6, 2008
- Chillin, Hwy 64 Mocksville NC
What is that spring looking gizmo?Chasing an oil leak today.
Oil filter return tube.The 6.0 power strokes has a cartridge style oil filter that goes inside an alum housing and its spring loaded.The o-ring under the housing was leaking on mine.And no its doesnt make the filter cheaper.What is that spring looking gizmo?
The 2030 osha rules be lit!
I thought this was @rockcity 's Fudge Kitchen..5th grade field trip with my son to Chattanooga.
Ruby Falls underground waterfall
Lovers Leap Lookout - 7 states visible from here
they are slightly less ugly now that they offer them body color, but still uglyHideous is a mega-understatement. It looks like they had a stock flare that lined up with the bumper, then the DOT compliance department said "put some 3" wide extensions on those" and engineering said "OK".
Then marketing said "now get one of those desert racer widebody kits, and cut just the wide part off, and glue it on top of these already extended flares", and assembly said "Will do!"
I dunno. That might be worse. I can’t decide.they are slightly less ugly now that they offer them body color, but still ugly
back in the 90's when mini trucks and nd ground effects were so big a dude around here took alum house guttering,split it in half and put it on the bottom of his Ford Ranger.The 80's Rangers we’re real square so it didn’t look that bad.IJS, a Bronco with ree-dick-u-lus fender flares is old news:
The 50 plus crowd knows what’s up.
I'm only 44 and that is still pimp!The 50 plus crowd knows what’s up.
I get annoyed with modern devices and the inability to adjust the sound.The 50 plus crowd knows what’s up.
This is why you’re supposed to rotate your brake pads at every oil change. Rookie.New brake pads in my wife’s car and brushes in the alternator in my 4runner. 108,000 miles on the brakes… Might have been able to squeeze another half mile out of them.
View attachment 415009View attachment 415010
You think rotating the brake pads every 50k would make that much of a difference?This is why you’re supposed to rotate your brake pads at every oil change. Rookie.
