Random pic thread.
Dinner did not disappoint.
Lobster rolls, lobster tots, lobster bisque and a whoopie pie from Cousins Maine Lobster food truck this afternoon.
Freaking good!
I’ve had Cousins and I guess I’m a bit jaded. I grew up in the northeast where you could get 10 to 15, 2.5 to 3 lb lobsters right off the boat for $20 to $30. Lobster rolls up there are bigger with way more lobster. I ate off their food truck once, and once was enough.
You’ve never steered me wrong when it came to BBQ or ribs. If you’re heading up north, I can put you on some fantastic seafood.
So, when you run out of bullets, you throw the Anvil at them. Good plan! And if their playing possum, poke them with the Stick!:lol:
Attempted staged photo...definitely random. Not sure of the vibe I was looking for....but yep I think you summed it up.
Way to go Chevy. Remove everything to change/rebuild trans.. (likely a broken 3-5-R wave plate)
Finally separated. I don't see how you could change the catalytic converter without a ton of extra work when in the vehicle, given how difficult it was to get the motor/cat converter loose from the sub frame. Oi. It'll be fun to reassemble, but it will get done.
Edit: called it.
Found these little buggers while mowing today. Fixed their best back. Will check tomorrow an make sure momma came back.
Sent from my SM-G930T using Tapatalk
Left some twine over the nest overnight and the momma had cleared it and the babies look healthy. Went out last night and they were out of the nest hopping around.
Bossman picked up another project for himself over the weekend. Since all his employees get to drive cool stuff, he may as well too.
Plans are still up in the air, but considering it is complete; frame off restoration probably. Powdercoated parts, drivetrain modernized to yield a reliable DD.
