Someone has jokes at work![]()
looks like every other xj with a stinger
Not sure.Did that sit for a while? Single location spalling like that often starts at a corrosion site, so that may be the low spot where a tiny bit of water was sitting..
I assumed it was just typical wear like I've seen numerous times on them.
Is it usually in a single location like that, or in multiple locations that look like that one?
The single location is not what I would expect to see from overload or lack of lubrication, as that damage tends to affect a lot of the area of the bearing race or rollers similarly. That's why I was speculating corrosion. Maybe debris damage though. With water intrusion you would often see multiple spots like that on the down-facing side of the race, one or two or three spots where one or two or three of the rollers were sitting with water. A single point overload would be interesting, because it's hard to overload-fatigue one spot with only one roller. without doing similar stuff to adjacent areas while rotating.
I'm just curious, I like this kind of stuff. I'm sure you've already spotted by nerd tendencies.
The pinion had lost all preload so that may have some sort of contributing factor.
just flip it over and reinstall,there's plenty left on that side.View attachment 293475
Figured I'd throw the flywheel in my 4.2 f150 as it was getting hard to start after turning the motor multiple times per attempt to get it to run. No wonder. I'm not sure if it's visible but the teeth are tapered from the wear. Need to exchange the starter too, would bring the suck to kill the new flywheel.
) and its a flexplate eatin machine.Everything is right,tight and correct its just hell on flexplates, so much so he's in the middle of a four speed now.intake manifold gasket is what killed this one.. filled cylinders with coolant/water and hydro locked.. prior owner would crank it, if it wouldn't crank, he'd pull #1 plug and spin it and then reinstall plug and run it. So it was already effed when I got it. I did the intake & valve cover gaskets and rolled on.. waited till it hardly wouldn't start to fix it.My dad has a 70's K-10 he put a 6.2 diesel in(yeah I know) and its a flexplate eatin machine.Everything is right,tight and correct its just hell on flexplates, so much so he's in the middle of a four speed now.
I sure could flip the ring gear around.. but for $45, it wasnt worth firing up the grinder & welder.just flip it over and reinstall,there's plenty left on that side.![]()
My fishing reel finally got a bath yesterday.
I should probably take that out of my truck
Dinner time!Momma went to bed early tonight so I thought I'd get some outside stuff done since the weather is perfect right now. Moving a couple flowers between the house and garage to make a walkway. Dug up three hydrangeas and went to cut a root that was in the middle of them and the leaves under my garage trim started to move....
That's pretty cool. It's amazing where battery technology has gotten to.![]()
New battery powered welder at work. Fronius AccuPocket 150 Battery-Powered Stick Welding Machine
Until you anchor at the sand bar and every rug rat in a square mile is climbing all over your boat to ride on the slide.This looks like a heck of a lot of fun...
Real question though.. how necessary is it though? I guess I have a hard time imagining a spot that would need welying that either a) didn't have access to even 120v power to run a suitcase welder or b) you couldn't wheel in a small gas powered welder. Both of which would seem much more useful, more often, than a battery powered rig.
