Random pic thread.
My dad around 1965
I am a little concerned about the level of pride this seller has in their company
Big Leaf Magnolia tree. Theres a few acres of my property that have a ton of em. Best shade you'll ever find in the summer. They like well draining northern slopes.
What he said. If you don't live around us, you've probably never seen one. Theyre pretty cool and resemble a palm of some sort, in a way, kinda.
So to complete the circle on this
Back axle on the ASV has this simple design with a nut on either side so you can just take the nut loose and pull the hub off.
But for some stupid reason, on the front, it's a through shaft with a flange on the inside, so you have to pull the whole axle through the frame to get the inside hub off.
I'm sure it saves $3.46 and works great when it's new, but after 12 years of living in dirt and mud, it all becomes one piece.
View attachment 347027View attachment 347028View attachment 347029
That was waaaay too much work. Back was apart in 30 seconds. Front took 2hrs per side.
And this
Down at the shop til almost 1am trying to wrap up this skidsteer undercarriage rebuild. Was putting the nut on the last hub, torqueing it down to a mere 380ft-lbs, when it got easy, the socket end fell to the ground and the hub nearly shot off from the release of force.
View attachment 348692View attachment 348693View attachment 348694
When it happened, I literally just walked over, cut the light off, and closed the door.
I guess when Terex bought ASV, they realized it was dumb, and made a design change. Now it's threaded on both sides, and you don't have to drive the axle completely out to change the inner hub.
Oh it's a 50 footer for sure. Did you LOL at the rear shackle hangars?
I feel the “bracing” used to support the tub after losing the rear bed floor takes the cake. I crawled all under the damn thing I was so amazed. I considered telling Pete (guy who owns Meineke) how horrible it is just in case he’s helping to sell it but anyone with decent eyesight should see the mess.
If they wait long enough someone will probably buy it, sadly.
Native to only to north eastern Gaston county from what I've researched. I think that's pretty cool.
Nah...that's a magnolia macrophylla - native to Mexico and the Carribean.
Its actually introduced in the US and naturalized.
Takes a fairly unique cliamte but can excel in crappy rocky soils
