Buddy Holly
Professional Amateur
- Apr 6, 2014
- North Raleigh
Hey everyone, this is the build that will document all the stuff I have done and will be doing to my little red YJ my buddies have dubbed Scarlet. It started out as a nearly stock 95 4banger that my dad bought back in 2010. It had a nasty 2" BL and add a leaf setup and some cheap 32s. We wheeled Potts Mtn many times with her when we still lived in VA. Once we moved to Raleigh it started to develop an oil pressure issue. At 3psi of oil pressure we yanked the 4banger out and rebuilt it over the summer. As you can see the bearings were toast.
Two days before I started college we had it up and running again. Here is the earliest pic I have on file after we threw on some 33 Duratracs and Bushcrackers. Still rocking the chrome crap from the PO
It was so clean back then!
So with the YJ running strong again I drove it pretty much as is for a while. Replaced the D35 with an 8.8, bent the 8.8 housing, threw in another 8.8.
Threw in a cage, some armor, etc. Long story short I wheeled the shit out of this Jeep in the summer of 2015 with no issues until New Years Day came around. In one day at Rausch Creek I managed to destroy a sidewall, the front d30 disco mechanism, the rear Spartan, and yet another muffler (in one year I have killed 6 mufflers).
I was able to get a set of 33s and wheels from a friend and limp it home. Made it back, threw in a Yukon Grizzly out back and converted the D30 to 1 piece shafts. That pretty much brings it up to date. Current pic:
Here is a current list of stuff done:
Modified Trail Gear cage w/ harness bar
suspension seat and 5 pt harness
Barnes rocker guards
Swag body mounts, welded to provide 1" lift
Custom 1" lift motor mounts
8.8, 4.10s, Grizzly
HP30, Spartan, 1 Piece shaft conversion, 4.10s
Metric 33" Fierce MTs and ATX knockoff Hutchinson wheels
Marked Designs front bumper/LOD rear tire carrier
SYE/driveshaft
It was so clean back then!So with the YJ running strong again I drove it pretty much as is for a while. Replaced the D35 with an 8.8, bent the 8.8 housing, threw in another 8.8.
8.8, 4.10s, Grizzly
SYE/driveshaft
