Down&Dirty
- Jun 26, 2005
- Greenville SC
All of the surfboards I have ever used had a plywood rib down the middle to keep it from snapping in half too easy. The reason I use the plywood is because I can build the whole thing with wood. I am used to doing woodwork so it is a comfort level thing. Then if I like it I can either paint, epoxy coat, or glass. Working with foam is not the cheapest thing to do. To make clean cuts you need a hot wire, most of us do not have access to one. Then you would have to shape it. This is really messy. By building a wood structure and insulating, you don't have a lot of foam work to deal with. You cut the foam to the right shape with a saw and glue it in. Also with just foam you would be required to do several more layers of fiberglass since all the strength is in the glass work. I took some pictures of a back cover that I was working on and will try to get them uploaded today.
edit:
Another question for you. Could you switch the way the top storage opens? make it open to the inside so that it would be the camping storage. Then a regular camper top would work and you gain a lot of access to camping supplies.
edit:
