JL Marvin
- Nov 2, 2008
- Union Grove NC
you could run a MSD distibutor to save space, or theres a kit to convert a points dist. to HEI for around $150! but price might have gone up.
yes, but the Stock HEI takes up more room than a converted points dizzy b/c of the integrated coil. I wouldnt change though just cheat the engine forward till it clears or get out the BFH.
why dont you fab to use the mount that came with the engine?
yeah cheating forward wont change anything that you'll notice. I mean its a trail rig if it saves you tons of work then I'd do it unless you plan to be having to change directions quickly at 200MPH![]()
That big U shaped thing is called a motor plate its a drag car thing.
What do the tens of thousands of other 350-toy swaps use for mounts?I wouldn't use the motor plate at all personally. It's for solid mounting your whole drivetrain in a solid car. Which your yota is not.What do the tens of thousands of other 350-toy swaps use for mounts?
I'm gonna have to make some motor mounts like these....I nabbed this pic from Crash's v8 4runner swap. He does awsome work.
Crash...Seattle,WA? Dank nasty stuff
If you run the rear mount radiator then just run the lines down the outside of the frame rails and build ya some sliders that work worth a damn to protect the line.
good to see ya gettin it done.
