SXOR single seater build
Absolutely! I killed my beadbuster from use and bought the HF HD version. What a time saver they are!!!!
I got the XB550i, it’s a little more HD than the standard one. It says it will do up to tractor tires. My M18 3/8” impact worked perfect on it.
I have that one too. Broke and fixed twice at least. Usually the roll pin in the nut gets sheared with the 1/2 impact. I've done my H1's regular 15's and 17's and the old ford tractor tires.
Got the shafts and hubs installed this morning. Need to grease the joints and install and bleed the brakes.
Reason I ask is because I had a couple of my CTM caps walk so I started tacking them. I've read others having the same issue. 👍
I’ve definitely heard those stories too. I had planned to do the loctite bearing retainer compound on the caps. I forgot it when I assembled them. So I asked Lee if I should and he said he’s never had any issues with them.
I got the brakes bolted up yesterday morning.
My old Stazworks wheels don’t fit over the ‘05+ hubs. The center bore needs to be opened up about .030”. We’re on the way to the beach right now so I’ll take them to get machined when we get back next week.
The 39” Reds sold yesterday too so I’ll be ordering some 43s when we get back as well.
This thing has been on jack stands since 2018 sooo… :laughing:
But you didn’t sell out! That’s the main thing. Jabs intended to everyone else.
