Absolutely! I killed my beadbuster from use and bought the HF HD version. What a time saver they are!!!!If you don’t have a BeadBuster I highly recommend getting o
I have that one too. Broke and fixed twice at least. Usually the roll pin in the nut gets sheared with the 1/2 impact. I've done my H1's regular 15's and 17's and the old ford tractor tires.Absolutely! I killed my beadbuster from use and bought the HF HD version. What a time saver they are!!!!
Are you going to tack weld the U-joint caps?
No. I talked to Lee @PCR, I ordered through him, he said he doesn’t do his.
I’ve definitely heard those stories too. I had planned to do the loctite bearing retainer compound on the caps. I forgot it when I assembled them. So I asked Lee if I should and he said he’s never had any issues with them.Reason I ask is because I had a couple of my CTM caps walk so I started tacking them. I've read others having the same issue.![]()
I’ll be ordering some 43s when we get back as well.
Treps only come in 42s![]()
Hopefully you get more use out of yours than I have mine lolNew meats are ordered thanks to @Noel. Wheels are at the shop to have the center holes opened up.
This thing has been on jack stands since 2018 sooo…Hopefully you get more use out of yours than I have mine lolbut I did start on the drive shaft this evening.
But you didn’t sell out! That’s the main thing. Jabs intended to everyone else.This thing has been on jack stands since 2018 sooo…![]()
