Just a comparison on the 14bolt shafts versus fzj80 9.5" shafts.
Here is the axle mostly done. Well so I thought.
We were flexing the truck to see if I could run the rear shocks outboard of the frame. The new springs really didn't flex much but I was able to determine that there is room!
YES these are parking brake cables! I measured and ordered like three sets of cables and the best ones that fit were from a Ford Ranger.
I needed the T connector style up front for the e-brake connector. And the other end is a wire screw/stop. Calipers were from lugnut4x4.
So here is where it goes sideways.
I couldn't bleed the brakes for shit. I tried and tried. Summed up it must be the master cylinder is not enough bore to push the fluid for the new large rear calipers.
Worked fine for the fzj80 toyota calipers but not these new larger 14nb calipers combined with the 44 front calipers. Too much fluid.
So I tried a larger booster and was just too much to hack and fit and I'd never be able to reach the #6 spark plug or replace the valve cover ever again without removing the booster.
So I made the decision to go hydroboost.
I got this from a disc rear Savannah van iirc 34mm bore.
I also had a hydro steering setup in a box from a friend out West. I figure if I'm going to do Hydro, I may as well do the whole thing now.
I cobbled all the plumbing together from SRI up in Mooresville and replaced the pulley with a smaller diameter Low range offroad pulley. This was really a pain in the ass honestly.
The pump "fits" but in order to tighten one of the bolts with the LRoffroad pulley in the way I have to remove the pulley.
I had Jody tap an Isuzu box since it looks like a mirror of the Toyoda box but turns out after all the inside its actually different.
I talked to a few other guys about what they did to run hydro on an isuzu box. Trust me there aren't very many who done this but I was able to find a better spot on the box to tap and I put an NPT plug on one of the holes.
Bleeding this suckssssss. Its the bane of this setup. I'm also running royal purple so fluid aint cheap trying to burp and bleed is so much fun. /s
Some stuff is off the shelf, like these metric-to-sae short connector adapters. Not much of a silver lining but I'll take the win.
Now once all that was sorted out, I kept my anti-wrap bar that Chris (aka Marsfab) made up and I did a littler CaD to mock it in place.
I cut the brackets and welded it in place. But I was still getting a knock from the huge CV head from time to time.
Even though I already cut the parking eBrake cable area in the floor it wasn't enough.
I then had to cut the cross member and rewelded it to give the head more room to spin.
Its about 1/2" maybe 5/8" difference but its all I needed.
