Small update.
I have been out wheeling but not much.
Flats once, Uwharrie twice, and then DPG once.
Plus after wheeling all the above having to drive there, I realize now I need to get my Low gears installed and crawling will be much more fun. Second, I need to save up some cash to get a damn tow rig.
I had overheating issues I needed to take care of. Earlier this year, I tore the entire engine down from the top, replaced the coolant pipes, hoses, valve cover gaskets, intake ring set, lower cooler lines, replaced the radiator, water pump, timing belt, drive belts, literally everything you would find on the way in. Why not while you're there, may as well.
I sent off the Fuel Injectors to
InjectorPulse for cleaning and testing. The send you back a report and how you should reposition them on install. Highly recommended service and quick too.
I also found a guy up the road that makes professional racing heads to dip clean my upper and lower intake knock off some of the carbon build up.
Here is some of my mess on the floor.
Been driving my truck around here and there and working on that damn Dodge Dakota I had to sell, and now I have the white BMW X5 back to fix and sell so I've been busy.
But I did get my Tcase gears installed. I've had quite the experience putting these in. Not gonna bore you with Isuzu gear tooth count madness but turns out the tcase I had has some newer tooth count gears and I had to mix and match another set with an older rear housing to get it right.
Can't wait to hit the trails now.
3:1 reduction now in stead of 2:1.
52:1 crawl ratio in 1st gear 4Low now instead of 34
I 'tested' the new gears in 2Lo and didn't even need to touch the gas letting the clutch out. Couldn't believe how slow this thing crawls now, just with Idle.
Planning a camp trip to Uwharrie in the Fall, nothing crazy, just missin some dirt and my truck isn't a street princess. I've got some other ideas down the road, tow rig, front bumper, different rear axle, better wheels.... all in due time.
