there is a plug on the driver side front of the block just under the alternator bracket that a sending unit can be relocated to. the plug taken out works in the hole at the top of the block.I flipped my intake 180 last night on my LS1...it appears that the only sensor that will have to be moved is what seems to be an oil pressure sending unit. If I could locate a right angled 16m tube adapter I think it would take care of the problem.
Valve covers swap from one side to the other so vent and fuel line pluming is stock...
EDIT: So I've read some more... the ECU doesn't use this oil pressure sending unit...this is just for the gauges...so...I don't need it...
Instead of finding a 16M tube pluge (the kind with the O-ring/bushing seal) I'm gonna break off the plastic piece of the sensor and weld it up...
Oil pressure guage will get plumbed into the cast piece right above the oil filter with a drill and 1/8NPT tap...
This should be it as far as a stock intake flip.
i would be curious to know how many had been run low in oil at some point or another. due to poor pcv system designs, they tend to burn more than most engines. the earlier ones were worse than later models. there were some changes made around 2000 or so i believe, but even those still consume more than "normal". i know when i worked at a gm dealer it was very common to get vehicles in that would have consumed 1-2 quarts between regular intervals of 3-5k miles.I work at a chevy dealer and there have been tahoes and silverados coming in with usually either low oil pressure or a noise at half engine speed. The first one that got torn down had spun the third cam bearing back and i believe the second motor we tore down was also that same cam bearing. Last thursday I got a silverado 113,000miles real bad chirping at half engine speed removed belts and found it coming from the center of the block customer chose to replace motor instead of tearing it down. Just today one came in that had low oil pressure and the noise I am not sure what happened with that yet but I think they ended up finding another problem with the cam.
The worst part is that they all seemed to be fairly well maintained and varied from construction company use to soccer moms. Now this could just be a certain batch of motors because iirc they seemed to all be around 03' but the milages have varied from around 70k-130k
hope that helps if we end up tearing down another one soon i will try to take pictures of the failed areas
What clutch are any of you running if anyone has a manual behind their LS? I am putting a 5.3 in front of a NV4500 (once I get it rebuilt) and am not sure what a good choice would be. Thanks. -Brandon
any info collected on where to get a stock harness if you didnt get it with the engine?What about the 8.1L????? I know you looked into it Rich.
If you MUST use a manual, a regular truck clutch should likely be just fine. low range takes a lot of the stress of it, as does the lighter weight of our rigs.
My favorite clutch is a torque converter.
I like the idea of a manual in a go fast rig. Do many of the KOH cars run manuals?If I were building a dedicated KOH car it would def. be an LS motor hooked to a nv4500. For trail riding, not so much.
Yup. they apparently cut off the wrong o2 sensors at Jim's Performance when they thinned out my harness, (pre cat instead of post cat). I was wondering about it when I put it together why the o2 sensor connectors wouldn't plug up. I originally had a set of pre cat sensors, and replaced them with post cat sensors. They plugged right up to the harness, but the computer is not happy with it like that. It runs, but waaaaay rich. I guess I have to call Jim on Monday.o2 sensors? Without those it will run rich. I just talked to him yesterday about this very same thing...
