Rich
Asshole at large
- Mar 17, 2005
- Central PA
I get asked probably weekly about the 5.3 LSx in my rig, so I figured I'd put the info out here...
DISCLAIMER: The information presented here is to the best of my knowledge through the research I've done, my first-hand experience, and what a few trusted sources have told me. I will update it as more information is provided or errors are corrected. Do your homework.
THE BASICS
This is only MY experience with MY engine. YMMV.
THE BASICS
- Most of your 5.3's and 6.0's are iron block / aluminum head, though the earliest 6.0's had iron heads, and there are some all-aluminum 5.3's and 6.0's around as well.
- All the f-body/corvette 5.7 LS1's are all-aluminum.
- iron/alum engines weigh 80-100lbs less than an all-iron Gen II engine. an all-aluminum engine weighs 80-100lbs less than that.
- 5.7's and 6.0's seem to command a 2x premium in price over the 5.3.
- They don't seem to handle being run without oil as well as the Gen II small-blocks. You've been warned.
- The 5.3/6.0's went to throttle-by-wire in 2002-2003 - your choice to use it or not, the conversion parts back to cable-pull can be had off fleabay for ~$100 (new TB, and PCM, and your wiring harness needs to be modded for the correct plugs on the TB- more on that later)
- The truck/SUV (5.3/6.0) oil pans hang quite a bit lower than the f-body (camaro/firebird) oil pans. You'll want to swap or have yours modified. Here's the part number list..
- 12558251 - SCREEN (oil pickup)
Part#: 12558251
Manufacturer Part#: 12558251
(Qty: 1 x $33.91)
12558253 - DEFLECTOR (Windage Tray)
Part#: 12558253
Manufacturer Part#: 12558253
(Qty: 1 x $17.83)
12558762 -1998-2003 Camaro/Firebird LS1 Oil Pan
Part#: 12558762
Manufacturer Part#: 12558762
(Qty: 1 x $164.95)
12551577 - TUBE (Dipstick tube)
Part#: 12551577
Manufacturer Part#: 12551577
(Qty: 1 x $7.04)
12551581 - INDICATOR (Dipstick)
Part#: 12551581
Manufacturer Part#: 12551581
(Qty: 1 x $9.99)
- Other oil pan options: http://www.ls1tech.com/forums/showthread.php?t=817787&highlight=h3+pan
- The truck intakes sit quite a bit taller than the car's, but do flow slightly better. You can swap the car's intake, but you might want to swap the whole accessory setup off the car as well, because the alternator sits way up high on the trucks and the water pump outlet can cause interference with the throttle body. A little grinding can fix that though.
- From Will @ Rockbottom4x4: I flipped my intake 180 last night on my LS1...it appears that the only sensor that will have to be moved is what seems to be an oil pressure sending unit. If I could locate a right angled 16m tube adapter I think it would take care of the problem.
- Valve covers swap from one side to the other so vent and fuel line pluming is stock...
- EDIT: So I've read some more... the ECU doesn't use this oil pressure sending unit...this is just for the gauges...so...I don't need it...
- Instead of finding a 16M tube pluge (the kind with the O-ring/bushing seal) I'm gonna break off the plastic piece of the sensor and weld it up...
- Oil pressure guage will get plumbed into the cast piece right above the oil filter with a drill and 1/8NPT tap...
- The intake manifolds have been known to leak - cheap insurance is to change the gaskets when you first get the engine.
- I *like* the truck accessory drive because it puts the PS pump down low (easier to get a good gravity feed from a reservoir) and the alternator up high where it won't get splashed.
- Truck water pumps have the output facing approx 45° up and to the right. 'vette/f-body pumps exit straight out the front. Only the 1997 corvette water pump has a bolt-on pulley that makes spacing it out ~3/4" easy. Most parts houses just stock the press-on pulley pump.. look around!
- The car accessory drive setup is slightly shorter front to back than the truck setup if space is really at a premium.
- A standard "metric" ('80-? according to PSC's site) Saginaw pump will directly in place of the OEM. Experiences with aftermarket pumps have been VERY mixed. You've been warned.
- I used intakehoses.com for the piping from throttle body to MAF and to the filter. Measure your MAF and TB. some will require a 3.5" end, some will require a 3". Their "cobra head" elbow protrudes very little to the front of the TB.
- For an off-road only rig not needing the emissions crap, you can have the harness thinned out and the computer re-flashed by several companies.. I (and several others) have used www.jimsperformance.com with excellent results. His work is excellent, and prices very reasonable. He also converts the whole harness to be a 4 wire deal with its own fuseblock, and includes an OBD-II port wired in. Makes it very easy.
- F-body (maybe vette too) computers support 2-stage electric fans, the on/off temps can be programmed for each stage by your tuner.
- Truck PCM's support single-stage electric fans, the on/off temps can be programmed by your tuner. Mine come on at 195°, off at 180°.
- MSD coils or "high performance" spark plug wires don't do shit. The wires are so short, and the coils are a good design with plenty of time to recover from the last spark before delivering the next, since there is one for each cylinder.
- All exhaust manifolds can interchange between the engines, and can also be flipped upside down if needed. There's also the FWD 5.3's in some newer cars that pack the exhaust in very tightly.
- The catalytic converters on the f-body bolt right to the manifolds, plan on making your own flanges.
- Oil Filter-
- Spark Plugs-
- Valve cover gaskets- not normally needed, as they are a reusable o-ring design
- 5.3 Engine, 50k miles, complete - $840 (look on car-part.com and start making calls, don't assume that newer engines are always more expensive)
- Jim's Performance - thinning wiring harness, side exit, change plugs for cable-pull TB, re-flash PCM - $call him (Budget $600 and you'll be covered)
- F-body oil pan, pickup tube, baffle, dipstick and dipstick tube - $250
- Assorted exhaust manifolds - $40
- Flexplate spacer and longer bolts, GM parts - $65 (Needed for TH350/700R4 trans)
- Cable pull TB and 2001 PCM (not needed in all apps) - $100
- '97 vette water pump and pulley (not needed in all apps) - $80
- Air filter, intake elbows, etc - $100
- Misc bolts and other oddities - $if you have to ask...
I know you looked into it Rich.
