The Senior Project
Those should work, I'd clean the threads up with a wire wheel and anti-seize on the threads during assembly.
Sent from my mobile Toyota base using Tapatalk
I like those rear disk brakes you have
Most of the time the nuts will not fit into the perches center hole.
Just c-clamp the pack together & flip the pin. Will probly need to use vice grips to unbolt the pins.
Sent via telegraph
