The Senior Project
Sweet man looking good! What springs did you use?
You might be able to use full size jeep wagoneer front springs with the stock hangers. Ill probably use some s10 springs on mine but the hangers will need to be moved.
You can also use xj rear springs. I've used the boomerang shackles before on my old cj and that worked pretty good.
Xj springs will get you six inches of stretch and waggy springs will get you 2" of stretch. S10 springs will get you four inches of stretch but the springs are longer.
Actually the waggy springs should stretch you 2" so you shouldn't have to move your gas tank.
Well was out cleaning the front hub bearings and looks like they are gonna have to be replaced. I also looked at the diff clearance to the gas tank and looks like 2 inches is as far as I can stretch without modding the gas tank . Here's a pic of the needle bearing in the hub. This is the worst one. The others just had rust.
from looking online drilling the leafs is a bad idea. alot of people have said they have broken. and i was thinkin of the waggy springs in the rear but its a 2.5 lift over stock yj springs too and i want to keep it as low as possible. any idea on how to get two inchs and not have anymore lift
you could take a leaf or two out of the waggy springs for ride height
