The Senior Project
Brake lines on ! Now gotta fix a bad flare I made in the rear and then hopefully I can finish bleeding this weekend !
Just did a tapatalk update and pictures still sideway ! !!!!
my neck hurts from looking at your pics....here ya go
Just worked my magic while eating a bojangles bisquit...
Not alot going on today , gonna try to work on the rear shocks and see where I can mount them . I'll try to post some sideways pics
Sent from my iPhone while developing new Iron Man armor .
Suppose to be an update coming out from tapa talk to fix this sideways picture posting issue
Think if running these in the rear outboard . What you guys think ? Hope the picture shows up right this time .
Ok today I was measuring for my drive shafts the rear is 18 inchs and front is 38 inchs . I heard you can run a front in the rear but I'm not seeing anything online that is that short.
on an xj. you could run a front shaft in the rear of an xj after a SYE. do you think you're getting those confused since you had an xj before?
Nah just what I heard and was hoping not to have to spend big money for a rear drive shaft
You can have a front xj shaft cut down if you have a sye. Carolina power train in hickory does good work and they charge 90 bucks to have a shaft cut down and balanced. Just had a rear shaft done 2 weeks ago. I bought a front xj shaft at pull a parts in Charlotte for like 17 bucks.
Ok that's any year xj I should look for ? Anyone around hickory got one for sale so I don't have to make a trip to Charlotte this weekend ?
Got my new to me driveshaft shortened from Carolina Drivetrain . Would have had it put in but I bought the wrong ujoint ! I needed a 1310 to 1330 and I got the 1350 instead .
Looks good!
Havnt got to flex it out yet to check shock clearance yet . Still gotta shorten the front driveshaft . Left two big ruts in the yard trying to get up on a stump trying though !
Thanks , got to replace the caliper key on the driverside this week sometime . Can't wait to ride around at the farm with my lil boy . Anyone gonna be at the farm that might have some yj trans slide bolts they might sell let me know .
